pwm connector
pwm connector
pwm 2 pin connector? where can i get this local or is it only available on the site?
Re: pwm connector
The dimming port lead wire on the webstore is a two pack (one for actinic, one for daylight)? It is hard to see in the picture but I assume the other end is bare wire that can be paralleled together for multiple drivers.
Re: pwm connector
Is there a thread, or tutorial on how to wire in led drivers?
Re: pwm connector
It's easy. + on the RA to + dimmer, - on the RA to - on the dimmer. The markings on the RA wire may be reversed, so go by the actual pins instead. The pin-out is in the RA manual.chapboogie wrote:Is there a thread, or tutorial on how to wire in led drivers?
Re: pwm connector
7th page. It's a big picture on the page by itself.
Re: pwm connector
Thanks. I know why I missed it. The screen I was on was too small to see the pins without zooming in.
