need custom PDE help
jjdezek
Re: need custom PDE help
Post by jjdezek »
i changed these numbers and it moved the codes up to the top. what im not understanding is how do i get the ATO to display on the screen?
ReefAngel.LCD.DrawMonitor(15, 10, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 10, ReefAngel.Params.);
You need to add DrawStatus(x,y); inside the DrawCustomMain function. with x and y being the coordinates where you want it.
jjdezek
Post by jjdezek »
so i would put something like
DrawStatus(15,50)
and just plug it in anywhere in the drawcustommain?
By Jove, I think he's got it!
Don't forget the semicolon after the last parenthesis.
jjdezek
Post by jjdezek »
haha awesome got it. ok next step. how do you make the temp 1 text larger? along with ph?
jjdezek
Post by jjdezek »
You'll need to replace the current drawing of those parameters with the other function I gave you.
DrawParams(x,y);
jjdezek
Post by jjdezek »
so i replace this
with this
  y+=5;
  ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, x+45, y, buf);
jjdezek
Post by jjdezek »
or just plug in the DrawParams (15,10);
I would do the second but either would work. The first one You would have a problem because x and y are not defined in the drawcustommain, so you'd have to edit that bit.
I think your starting to get the hang of it :)
jjdezek
Post by jjdezek »
with this it didnt turn out. pic to follow.
#endif // defined DisplayLEDPWM && ! defined RemoveAllLig
DrawStatus (20,80);
DrawParams (15,50);
jjdezek
Post by jjdezek »
jjdezek
Post by jjdezek »
with this code set up
DrawStatus (20,80);
DrawParams (15,50);
jjdezek
Post by jjdezek »
I get this
Sorry, you need to add this to get the large numbers. This goes right after the // Place global variable code below here. Not inside the functions.
#define NUMBERS_8x16
As far as the alignment if it doesn't get fixed after that, try changing the x to 5.
jjdezek
Post by jjdezek »
all that did was make the text bigger still have the smaller numbers overlapping and those numbers a glitching.
jjdezek
Post by jjdezek »
it looks like the word temp and ph are behind the numbers instead of above them. I also noticed that when i removed the old params codes i removed the pwm block. is there away i can keep the pwm on the screen and remove the old params?
Lets address the pwm values after. That will be easy. Can you post your current code and screenshot.
jjdezek
Post by jjdezek »
well while i was waiting for your response i did a little playing with the code. i got my name displayed across the top and put the params back in. so right now this is what i have.
ReefAngel.LCD.DrawText(COLOR_INDIGO, COLOR_WHITE,20,5, "Jeremy's Reef");
ReefAngel.LCD.DrawMonitor(15, 30, ReefAngel.Params,
DrawStatus (20,80);
DrawParams (5,60);
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardLights( Port3,18,0,10,0 );
    ReefAngel.WavemakerRandom( Port5,30,100 );
    ReefAngel.WavemakerRandom( Port6,30,100 );
    ReefAngel.StandardHeater( Port7,752,755 );
    ReefAngel.PWM.SetChannel( 0, PWMSlope(7,0,22,0,0,40,180,0) );
    ReefAngel.PWM.SetChannel( 1, PWMSlope(7,30,21,30,0,35,180,0) );
    ReefAngel.PWM.SetChannel( 2, PWMSlope(7,0,22,0,0,40,180,0) );
    ReefAngel.PWM.SetChannel( 3, PWMSlope(7,30,21,30,0,35,180,0) );
    ReefAngel.PWM.SetChannel( 4, PWMSlope(7,0,22,0,0,40,180,0) );
    ReefAngel.PWM.SetChannel( 5, PWMSlope(7,30,21,30,0,35,180,0) );
    if (hour()>=8 && hour()<12)
  ReefAngel.PWM.SetDaylight( ReefCrestMode(100,20,true) ); // ReefCrest at 100% +/- 20% on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(100,20,false) ); // ReefCrest at 100% +/- 20% on anti-sync mode
else if (hour()>=12 && hour()<18)
  ReefAngel.PWM.SetDaylight( ShortPulseMode(0,100,200,true) ); // Short pulse at 100% with 200ms pulse on sync mode
  ReefAngel.PWM.SetActinic( ShortPulseMode(0,100,200,false) ); // Short pulse at 100% with 200ms pulse on anti-sync mode
  ReefAngel.PWM.SetDaylight( LongPulseMode(0,100,10,true) ); // Long pulse at 100% with 10s pulse on sync mode
  ReefAngel.PWM.SetActinic( LongPulseMode(0,100,10,false) ); // Long pulse at 6100% with 10s pulse on anti-sync mode
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
   ReefAngel.PWM.SetActinic(0);
   ReefAngel.PWM.SetDaylight(0);
    ReefAngel.Portal( "jjdezek" );
void DrawParams(int x, int y) {
  char buf[16];
  // Temp and PH
  y+=2;
  y+=5;
void DrawStatus(int x, int y) {
  int t=x;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"High",Font8x16);
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,y,"Low",Font8x16);
  } else {
  } else {
jjdezek
Post by jjdezek »
I want to keep the DP AP part of the params and delete the rest. is it easy to change the name from DP to say WP40L and AP to say WP40R?
Yes it's all very easy.
You will take out the block of code that is drawing the rest of the parameters and add something like this:
DrawText(DPColor,DefaultBGColor,x+60,y+10,"DP:");
DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+78, y+10,1);
DrawText(APColor,DefaultBGColor,x+60,y+20,"AP:");
DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+78, y+20,1);
you will need to play with the x and y and change the DP and AP to what you want
The DrawText function prints your label and the DrawSingleMonitor draws the values.
jjdezek
Post by jjdezek »
easy for someone who knows what there doing maybe but is it easy for someone like me lol. ok so whats the x+60 mean, is that where its placing it on the screen? I tried plugging it in and get error not defined in scope?
jjdezek
Post by jjdezek »
is this what you mean by changing the DP and AP?
DrawText(WP40LColor,DefaultBGColor,x+60,y+10,"WP40L:");
DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), WP40LColor, x+78, y+10,1);
DrawText(WP40RColor,DefaultBGColor,x+60,y+20,"WP40R:");
DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),WP40RPColor, x+78, y+20,1);
yes but don't change it for the colors... since WP40LColor and WP40RPColor are not defined... :)
jjdezek
Post by jjdezek »
so like this? now where do i put this exactly? in the bottom section or in the section between the global variable? I tried both but got the error saying not declared in this scope.
DrawText(DPColor,DefaultBGColor,x+60,y+10,"WP40L:");
DrawText(APColor,DefaultBGColor,x+60,y+20,"WP40R:");
DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+78, y+20,1);
This would all go inside your DrawCustomMain() function like you did with DrawStatus() and DrawParams(),
I see what the error is. I copied the code directly from the library function that does DrawMonitor...
so to use it in your code, you need to change DrawText to ReefAngel.LCD.DrawText and change DrawSingleMonitor to ReefAngel.LCD.DrawSingleMonitor.
Sorry about that.
jjdezek
Post by jjdezek »
so i changed it like this
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x+60,y+10,"WP40L:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+78, y+10,1);
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+60,y+20,"WP40R:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+78, y+20,1);
and put it in here
ReefAngel.LCD.DrawText(COLOR_INDIGO, COLOR_WHITE,25,5, "Jeremy's Reef");
DrawStatus (20,80);
DrawParams (5,60);
and got error the x and y are not declaired in this scope
jjdezek
Post by jjdezek »
ok i moved it into the bottom portion with the custom params section and it loaded. just got to figure out the placement.
jjdezek
Post by jjdezek »
thats not working all my params i.e. temp ph and pwm readings are all ontop of eachother.
ok did some more playing and created a new paramsa section to put the pwm files in so i can place them in there own area. :D
