wow just saw that so i removed one of the water changes and still nothing heres the code
static byte wpMode;
ReefAngel.WaterChangePorts = Port4Bit;
ReefAngel.LightsOnPorts = Port6Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardHeater( Port1 );
ReefAngel.DosingPumpRepeat1( Port3 );
ReefAngel.DosingPumpRepeat2( Port5 );
ReefAngel.DayLights( Port6 );
ReefAngel.ActinicLights( Port7 );
ReefAngel.PWM.Channel0PWMSlope(40);
ReefAngel.PWM.Channel1PWMSlope(10);
ReefAngel.PWM.Channel2PWMSlope(20);
ReefAngel.PWM.Channel3PWMSlope(35);
ReefAngel.PWM.Channel4PWMSlope(25);
static time_t feeding;
// Time schedule first
if (hour()>=6 && hour()<9) {
//ReefAngel.PWM.SetDaylight( TidalSwellMode(45,true) ); // TidalSwell at 45% on sync mode
ReefAngel.PWM.SetActinic( TidalSwellMode(30,true) ); // TidalSwell at 30% on sync mode
wpMode=1;
} else if (hour()>=9 && hour()<12) {
//ReefAngel.PWM.SetDaylight( ReefCrestMode(70,20,true) ); // ReefCrest at 70% +/- 20% on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(40,20,true) ); // ReefCrest at 40% +/- 20% on anti-sync mode
wpMode=2;
} else if ( (hour()>=12 && hour()<15) && (now()-feeding > SECS_PER_DAY) ) { // We haven't fed today
// ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,60,6000,true) );
ReefAngel.PWM.SetActinic( NutrientTransportMode(25,35,6000,true) );
wpMode=3;
} else if (hour()>=15 && hour()<18) {
// ReefAngel.PWM.SetDaylight( ReefCrestMode(70,20,true) ); // ReefCrest at 70% +/- 20% on sync mode
ReefAngel.PWM.SetActinic(ShortPulseMode(15,42,3000,true));
wpMode=5;
} else if (hour()>=18 && hour()<20) {
wpMode=2;
} else if (hour()>=20 && hour ()<23) {
// ReefAngel.PWM.SetDaylight(SineMode(20,40,30,true) ); //SineMode from 20% to 40% for 30 seconds on sync mode
ReefAngel.PWM.SetActinic(SineMode(20,40,30,true) ); //SineMode from 20% to 40% for 30 seconds on sync mode
wpMode=4;
} else {
//ReefAngel.PWM.SetDaylight(SineMode(15,40,30,true) ); //SineMode from 15% to 40% for 30 seconds on sync mode
ReefAngel.PWM.SetActinic( TidalSwellMode(20,true) ); // TidalSwell at 20% on sync mode
wpMode=1;
// If we are feeding override the schedule
// ReefAngel.PWM.SetDaylight(30);
ReefAngel.PWM.SetActinic (0);
wpMode=0;
feeding=now();
// If we have finished feeding, start NTM for 3 hours
if (now()-feeding < 3*SECS_PER_HOUR) {
//ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,60,6000,true) );
ReefAngel.PWM.SetActinic( NutrientTransportMode(25,40,6000,true) );
wpMode=3;
if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) {
//ReefAngel.PWM.SetDaylight(0);
ReefAngel.PWM.SetActinic(0);
ReefAngel.Portal( "805reefer" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// WP40 Mode
x = 15;
y = 33;
ReefAngel.LCD.DrawText(0,255,x,y,"RF:");
ReefAngel.LCD.Clear(DefaultBGColor,x,y,128-x,y+8);
if (wpMode == 0) ReefAngel.LCD.DrawText(COLOR_GREEN,255,x,y,"Feeding");
else if (wpMode == 1) ReefAngel.LCD.DrawText(COLOR_MAGENTA,255,x,y,"Tidal Swell");
else if (wpMode == 2) ReefAngel.LCD.DrawText(COLOR_GOLD,255,x,y,"Reef Crest");
else if (wpMode == 3) ReefAngel.LCD.DrawText(COLOR_RED,255,x,y,"Nutrient");
else if (wpMode == 4) ReefAngel.LCD.DrawText(COLOR_BLUE,255,x,y,"Sine Wave");
else if (wpMode == 5) ReefAngel.LCD.DrawText(COLOR_GREEN,255,x,y,"Short Pulse");
