ORP calibration with 220mV fluid
PostPosted: Tue Jun 11, 2013 4:51 am
Hi All
Can anyone help me with the code that I would need to calibrate my ORP if I have 220mV fluid?
PostPosted: Tue Jun 11, 2013 8:59 am
You need to update the libraries, but the problem with updating the libraries is that everytime there is an update, it will overwrite the changes you've made.
But, if you want to give it a shot, you must change the lines:
https://github.com/reefangel/Libraries/ ... l.cpp#L886
https://github.com/reefangel/Libraries/ ... .cpp#L5513
Look for the 470 and change it to 220 or whatever standard that you have.
PostPosted: Wed Jun 12, 2013 3:12 am
Thanks Roberto
To be honest, I am not a code person at all... I tried to take the relevant lines from your links and put them into my code, but I got the error "'Params' was not declared in the scope" or "'ORP' was not declared in this script. Here is my code at the moment:
#include <LCD_Timer.h>
    ReefAngel.Timer[LCD_TIMER].SetInterval(84600);
    ReefAngel.PHMin=523;
    ReefAngel.PHMax=828;
    ReefAngel.SetTemperatureUnit( Celsius );  // set to Celsius Temperature
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit;
    InternalMemory.OverheatTemp_write( 290 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardATO( Port1,1000 );
    ReefAngel.WavemakerRandom1( Port5,15,60 );
    ReefAngel.WavemakerRandom2( Port6,15,60 );
#if defined ORPEXPANSION
   unsigned long temporp=0;
    for (int a=0;a<20;a++)
       temporp+=ORP.Read();
   Params.ORP=temporp/20;
   if (Params.ORP!=0)
      Params.ORP=map(Params.ORP, ORPMin, ORPMax, 0, 470); // apply the calibration to the sensor reading
      Params.ORP=constrain(Params.ORP,0,550);
   RefreshScreen();
#endif  // defined ORPEXPANSION
    ReefAngel.Portal( "Graham2212" );
    int x,y;
    // Parameters
    // Salinity
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
     // ORP
    ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,75,54, "ORP:" );
    ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,99,54, ReefAngel.Params.ORP );
    // Main Relay Box
    // Date and Time
Is there anyway to say maybe "UseFlexibleORPCalibration()" under the setup section, so that I can define in reef angel, that I am using 220mV?
Thank you
PostPosted: Wed Jun 12, 2013 10:07 am
Oh, it won't work if you use in your code.
It needs to be changed in the libraries itself. That's why I said is not a good practice to do that.
Nobody created a "UseFlexibleORPCalibration()" yet.
Maybe if you bug phrusher long enough, he may be able to do that for us :)
He was the one that created the "UseFlexiblePHCalibration()" function.
PostPosted: Wed Jun 12, 2013 10:10 am
I can take a look, but I would have no way to test :)
PostPosted: Wed Jun 12, 2013 1:04 pm
I'm very happy to test!! I would really appreciate your help!!
PostPosted: Sat Jun 29, 2013 4:41 pm
Hi
I would be really interested in this as well, I have found it impossible to get the 470mv calibration fluid in the uk, some say they can get it but 2 months on nothing.
PostPosted: Sat Jun 29, 2013 4:45 pm
Sorry i have not had any time to put something together for this..
PostPosted: Sat Jun 29, 2013 4:51 pm
lnevo wrote:Sorry i have not had any time to put something together for this..
Sorry no pressure just wanted to register interest :-)
I raised this a while ago and didn't like the idea of messing with the libraries, especially after reading so many posts that said it wasnt wise.
Thanks for the reply though :-)
PostPosted: Sat Jun 29, 2013 4:56 pm
Next
Return to Ask anything here
