Trouble with setting multiple times for WP40 modes
markywmson
Re: Trouble with setting multiple times for WP40 modes
Ok, thanks Lee
I haven't had time to get in and update these, hopefully Sunday night. Work and my 5 month old twins and wife are keeping me busy busy. As soon as I can try this (hopefully with a beer in hand) I will report back.
Thanks again!
-mark
Thanks again!
-mark
Nice...keep us posted. I couldn't imagine dealing with twins...my one month old is enough work all on his own.
markywmson
Still waiting to try this... but had another question as I was looking at graphs on the iPhone app (can't wait for the new one btw!)
If I see it correctly... TidalSwellMode ramps up to 45% from some other number. This works perfectly in the morning, but is there a way to inverse this, so it ramps down in the evening? Maybe I misunderstand this mode... (a distinct possibility)
markywmson
Hey Lee (or anyone else)
With all that custom stuff that was written for my WP40, with the new libraries, is that all old and outdated? Will it still work? Or do I have to make big changes to it?
-mark
-mark
You could leave it as is for now, it should still work. I dont know yet exactly how the new libraries are working. My guess would be we would have to modify it and we will no longer have to run the set daylight and pick what function to use, we will use SetMode lime we can do with rf
clw143
Is there a reason I can't do this:
Instead of this:
if (hour()>=8 && hour()<12) wp40mode=6;
else if (hour()>=12 && hour()<17) wp40mode=2;
else if (hour()>=17 && hour()<18) wp40mode=5;
else if (hour()>=18 && hour()<24) wp40mode=2;
else wp40mode=4;
if (wp40mode=6) ReefAngel.DCPump.SetMode( TidalSwell,80,10 ); // Tidal Swell at 80%
if (wp40mode=5) ReefAngel.DCPump.SetMode( NutrientTransport,70,10 ); // Nutrient Transport at 70% with 10ms pulse
if (wp40mode=4) ReefAngel.DCPump.SetMode( LongPulse,60,10 ); // Long pulse at 60% with 10s pulse
if (wp40mode=3) ReefAngel.DCPump.SetMode( ShortPulse,50,10 ); //Short pulse at 50% with 10ms pulse
if (wp40mode=2) ReefAngel.DCPump.SetMode( ReefCrest,40,10 ); // ReefCrest at 40%
if (wp40mode=1) ReefAngel.DCPump.SetMode( Lagoon,30,10 ); // Lagoon at 30%
if (wp40mode=0) ReefAngel.DCPump.SetMode( Constant,20,10 ); // Constant at 20%Code: Select all
if (hour()>=6 && hour()<11) {
ReefAngel.PWM.SetDaylight( TidalSwellMode(45,true) ); // TidalSwell at 45% on sync mode
ReefAngel.PWM.SetActinic( TidalSwellMode(45,true) ); // TidalSwell at 45% on sync mode
wpMode=1;
} else if (hour()>=11 && hour()<15) {
ReefAngel.PWM.SetDaylight( ReefCrestMode(70,20,true) ); // ReefCrest at 70% +/- 20% on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(70,20,false) ); // ReefCrest at 70% +/- 20% on anti-sync mode
wpMode=2;
} else if ( (hour()>=15 && hour()<18) && (now()-feeding > SECS_PER_DAY) ) { // We haven't fed today
ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,60,6000,true) );
ReefAngel.PWM.SetActinic( NutrientTransportMode(30,60,6000,false) );
wpMode=3;
} else if (hour()>=15 && hour()<18) {
wpMode=2;
} else if (hour()>=18 && hour()<20) {
wpMode=2;
} else if (hour()>=20 && hour ()<23) {
wpMode=1;
} else {
ReefAngel.PWM.SetDaylight(SineMode(15,40,30,true) ); //SineMode from 15% to 40% for 30 seconds on sync mode
ReefAngel.PWM.SetActinic(SineMode(15,40,30,true) ); //SineMode from 15% to 40% for 30 seconds on sync mode
wpMode=4;
I think either way works.
The only thing I need to point out is that the code if (wp40mode=6) is not a comparison, it's a assignment statement.
You should use if (wp40mode==6)
http://arduino.cc/en/Reference/If
http://arduino.cc/en/Reference/Assignment
If your going to use DCPump.SetMode you also need to set UseMemory=false; and you may want an option to break out and use the options in the portal in which case you would need a case where you can do UseMemory=true;
clw143
I'm confused, it seems to me this would be the assignment statementrimai wrote:I think either way works.
if (hour()>=8 && hour()<12) wp40mode==6;Code: Select all
if (wp40mode=6) ReefAngel.DCPump.SetMode( TidalSwell,80,10 ); // Tidal Swell at 80%- lnevo
== is comparison
= is assignment
= is assignment
clw143
ohhh got it, thanks
