WP40 only running in at constant mode
Appleseed
Post by Appleseed »
Hello
I am trying to get my wp40 to change modes at various times. I run my mp10 and 40's in a similar fashion without issues. The wp40 just seems to stay in a constant speed mode. I have connected the signal wire to the port closest to the serial port on the relaybox.
Any ideas would be apprecated.
Credit for the wp40 code goes to reeferbee btw.
if ( ReefAngel.RF.Mode != Feeding_Start)
          if (hour()==10)
            ReefAngel.RF.SetMode(ReefCrest,30,20);
         else if (hour()>=0 && hour()<1)
            ReefAngel.RF.SetMode(Lagoon,80,15);
         else if (hour()>=1 && hour()<2)
            ReefAngel.RF.SetMode(Lagoon,60,20);
         else if (hour()>=2 && hour()<3)
            ReefAngel.RF.SetMode(Lagoon,50,25);
         else if (hour()>=3 && hour()<4)
         else if (hour()>=4 && hour()<5)
            ReefAngel.RF.SetMode(Lagoon,70,10);
         else if (hour()>=5 && hour()<6)
           ReefAngel.RF.SetMode(Lagoon,60,15);
         else if (hour()>=6 && hour()<7)
            ReefAngel.RF.SetMode(Lagoon,50,20);
         else if (hour()>=7 && hour()<8)
            ReefAngel.RF.SetMode(Lagoon,40,30);
         else if (hour()>=8 && hour()<9)
         else if (hour()>=9 && hour()<10)
            ReefAngel.RF.SetMode(Lagoon,60,10);
         else if (hour()>=10 && hour()<11)
            ReefAngel.RF.SetMode(Lagoon,80,5);
          else if (hour()>=11 && hour()<12)
            ReefAngel.RF.SetMode(Smart_NTM,90,6);
          else if (hour()>=12 && hour()<13)
            ReefAngel.RF.SetMode(Smart_NTM,80,10);
          else if (hour()>=13 && hour()<14)
            ReefAngel.RF.SetMode(Smart_NTM,70,12);
          else if (hour()>=14 && hour()<15)
            ReefAngel.RF.SetMode(Smart_NTM,60,10);
          else if (hour()>=15 && hour()<16)
            ReefAngel.RF.SetMode(Smart_NTM,40,8);
          else if (hour()>=16 && hour()<17)
            ReefAngel.RF.SetMode(Lagoon,50,10);
          else if (hour()>=17 && hour()<18)
            ReefAngel.RF.SetMode(Lagoon,80,10);
          else if (hour()>=18 && hour()<19)
            ReefAngel.RF.SetMode(Constant,60,10);
          else if (hour()>=19 && hour()<20)
            ReefAngel.RF.SetMode(Constant,50,10);
          else if (hour()>=20 && hour()<21)
          ReefAngel.RF.SetMode(Constant,40,10);
          else if (hour()>=21 && hour()<22)
            ReefAngel.RF.SetMode(Constant,45,10);
          else if (hour()>=22 && hour()<23)
          else if (hour()>=23 && hour()<0)
            ReefAngel.RF.SetMode(Lagoon,50,15);
            ReefAngel.RF.SetMode(ReefCrest,40,8);
//    ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 60% +/- 20% on sync mode
//    ReefAngel.PWM.SetDaylight( NutrientTransportMode(80,100,10,true) );
    else if (hour()>=8 && hour()<10)
  ReefAngel.PWM.SetDaylight( LongPulseMode(0,40,10,true) ); // Long pulse at 40% with 10s pulse on sync mode
    else if (hour()>=10 && hour()<16)
  ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 75% + - 20 on sync mode
    else if (hour()>=17 && hour()<20)
    else if (hour()>=20 && hour()<24)
  ReefAngel.PWM.SetDaylight( TidalSwellMode(60,true) ); // Tidal Swell at 60% on sync mode
Re: WP40 only running in at constant mode
Because the code you are using is for the Vortech MP pumps using the RF module, not the WP40...
The functions you will need are going to look like ReefAngel.Relay.SetDaylight( ReefCrestMode(30,20,true) );
You are missing the initial "if"...
Change this:
To this:
ahh sorry missed the full code :)
Appleseed
Post by Appleseed »
:D
Thanks again Roberto that sorted it.
cheers
Andy
