PaulTurner911 Code
Paulturner911
PaulTurner911 Code
Post by Paulturner911 »
First I would have to thank Lee for "helping" get this dialed in.....
AND BY HELP I MEAN PRETTY MUCH DO IT FOR ME!!
He has been a great help in this from the start.
Currently Running:
Overflow Protection- Shuts down Return Pump
ATO Low Protection- Shuts down Aqua Lifter
Moon Phase from 9pm-10am
ATO/Kalk Doser running for 50sec every 15min from 8pm-12pm
Custom Feed Mode(WP40 off for 30min, Return Pump off for 60min)
WP40 Tidal Modes (Randomized Daily)
Night Mode for the WP40
ReefAngel.FeedingModePorts = Port1Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit | Port8Bit;
ReefAngel.StandardFan( Port2 );
ReefAngel.DayLights( Port7 );
ReefAngel.DayLights( Port8 );
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Pump Delay and Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 50sec @ 8pm-12pm (every 15min)
if (hour() >=20 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<50);
//Feed Mode Delay on Pump
static boolean feeding=false;
static unsigned long feedingstarted = now();
  if (!feeding)
  feeding=true;
} else {
  feeding=false;
///// Place your custom code below here
//IDK Rimai Posted
#define Mem_B_RFMode           VarsStart+55
// Read memory for RF Wave Settings and use for Tunze/Jaebo
int mode=InternalMemory.RFMode_read();
int speed=InternalMemory.RFSpeed_read();
int duration=InternalMemory.RFDuration_read();
// Change this to what you want your min/max based on vortech speed
// This is for those functions that take both, but only one memory slot.
int minOffset=25;
int maxOffset=25;
int min=speed-minOffset;
int max=speed+maxOffset;
// Add random mode if we set to Mode to 12
static int rmode;
if (now()%SECS_PER_HOUR==0) {
  rmode=random(7); // Change the mode once per hour to modes 0-6
if (mode==12) {
  mode=rmode;
// keep wavemakers off for first 30 minutes of feeding mode.
if (now()-feedingstarted<=1800 && ReefAngel.DisplayedMenu==FEEDING_MODE) {
    ReefAngel.PWM.SetDaylight( 0 );
    //ReefAngel.PWM.SetActinic( 0 );
} else if (mode==Constant) {
  // Constant
    ReefAngel.PWM.SetDaylight( speed );
    //ReefAngel.PWM.SetActinic( speed );
} else if (mode==Lagoon) {
    // Lagoon
    ReefAngel.PWM.SetDaylight( SineMode(min,max,duration,true) );
    //ReefAngel.PWM.SetActinic( SineMode(min,max,duration,false) );
} else if (mode==ReefCrest) {
    // Reef Crest
    ReefAngel.PWM.SetDaylight( ReefCrestMode(speed,duration,true) );
    //ReefAngel.PWM.SetActinic( ReefCrestMode(speed,duration,false) );
} else if (mode==ShortPulse) {
    // Short Pulse
    ReefAngel.PWM.SetDaylight( ShortPulseMode(min,max,duration,true) );
    //ReefAngel.PWM.SetActinic( ShortPulseMode(min,max,duration,false) );
} else if (mode==LongPulse) {
    // Long Pulse
    ReefAngel.PWM.SetDaylight( LongPulseMode(min,max,duration,true) );
    //ReefAngel.PWM.SetActinic( LongPulseMode(min,max,duration,false) );
} else if (mode==TidalSwell) {
    // Tidal Swell
    ReefAngel.PWM.SetDaylight( TidalSwellMode(speed,true) );
    //ReefAngel.PWM.SetDaylight( TidalSwellMode(speed,false) );
} else if (mode=NutrientTransport) {
    // Smart_NTM
    ReefAngel.PWM.SetDaylight( NutrientTransportMode(min,max,duration,true) );
    //ReefAngel.PWM.SetActinic( NutrientTransportMode(min,max,duration,false) );
} else {
    // Default
    ReefAngel.PWM.SetDaylight( TideMode(speed,minOffset,maxOffset) );
    //ReefAngel.PWM.SetActinic( TideMode(speed,minOffset,maxOffset) );
// Add night mode (constant 30%)
if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY >=81000) { // Time is before 8:30am and after 10:30pm
ReefAngel.PWM.SetDaylight(30);
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
http://forum.reefangel.com/status/chart ... ilter=PWMD
Last edited by Paulturner911 on Mon Jun 23, 2014 12:14 pm, edited 2 times in total.
Re: PaulTurner911 Code
Try this code, I added the following requested features:
Changed random mode to switch daily instead of hourly
Changed the duration for NTM and short pulse to use a better value (duration * 100) since the argument is milliseconds
Added in the NTM after feeding mode is done. (30 minutes pumps off, then 60 minutes of NTM)
Added indentations to make it readable.
  //ATO Protection
  //IDK Rimai Posted
  // #define Mem_B_RFMode           VarsStart+55
  int minOffset=25;
  int maxOffset=25;
  static int rmode;
  if (now()%SECS_PER_DAY==0 || changeMode=true) { // Change at midnight or if controller rebooted
    rmode=random(7); // Change the mode once per day to modes 0-6
    changeMode=false;
  if (mode==12) {
    mode=rmode;
  static unsigned long feeding;
    feeding = now();
  if (now()-feeding<=1800) { // 30 minutes after
  } else if (now()-feeding<=(1800+3600)) { // // First 30 minutes pump is off.. next 60 minutes will be in NTM
      ReefAngel.PWM.SetDaylight( NutrientTransportMode(min,max,duration*100,true) );
  } else if (mode==Constant) {               // Constant
  } else if (mode==Lagoon) {                 // Lagoon
  } else if (mode==ReefCrest) {              // Reef Crest
  } else if (mode==ShortPulse) {             // Short Pulse
      ReefAngel.PWM.SetDaylight( ShortPulseMode(min,max,duration*100,true) );
  } else if (mode==LongPulse) {              // Long Pulse
  } else if (mode==TidalSwell) {             // Tidal Swell
  } else if (mode=NutrientTransport) {       // Smart_NTM
  } else {                                   // Default
  int x,y;
  x = 15;
  y = 2;
    if ( a>2 ) x = 75;
    if ( a==3 ) y = 2;
    y += 10;
Paulturner911
Error:
Ivalue required as left operand of assignment
It need == instead of =
Paulturner911
Error
expected unqualified-id before "if"
Its this line above that...
It needs a {
Paulturner911
Thanks guys, it took!!
Lee, what is your duration set at?
If I understand(rarely) I would set it at 25 inorder for reefcrest to run @45 +/-25.
I did this in the portal, while saving all read "OK" but DC Pump Speed & Duration- both ERR
The libraries arent supporting dc pump yet.
Paulturner911
k, just seemed sketchy.
When I select custom in the portal ive only run 45 tonight no change (maybe it randomized 45 constant), Ill check to see if it changes tuesday. Night mode does work though! Just watched it click over.
Could I just remove ones that I dont want to run from this section??
} else { // Default
If you pick custom it will just do the tide mode which is almost a constant, unless you changed the mode==12 line.
Otherwise set the RFMode memory to 12 manually.
And it's very likely to have picked constant, it's only 1 in 7
Paulturner911
// Add random mode if we set to Mode to 11(Custom in Portal)
static int rmode;
changeMode=false;
if (mode==11) {
mode=rmode;
This should have made custom do my random function correct?
Yep
Paulturner911
We will know tomorrow. How can I remove modes?....like this lol
Well I would not take them out of your list of modes. You'll just end up in your default else more often..l
I'll post some code tomorrow you can use to pick which ones get used for random mode.
Paulturner911
I does seem to have picked a different mode today!! Maybe long pulse. I have 45 for speed and 25 for duration in the portal. I see that there is a tab for DC pump now, will I be utilizing that? BUT there isnt a "custom" selection. What is your duration set at Lee? I would like my PWM graph to look a bit more like yours.
Last edited by Paulturner911 on Tue Jun 18, 2013 11:43 am, edited 1 time in total.
I set my duration to 10 but I am doing things very differently. I don't have wp40s.
The dc pump section will be supported by the new libraries. I have no idea how that is going to work yet.
Paulturner911
I see! Maybe thats why its so flat. Ive set mine to 10. I just think Im going to end up wanting to randomize lagoon, reefcrest and long pulse. Im stoked to try NT after feedmode tonight!!!
The new libs have been pushed yesterday :)
Take a peak at the wizard.
Paulturner911
Cool! Ill check it out when I get home.
Paulturner911
OK, I jumped the gun and downloaded it at work. :)
I see in the wizard that you can set the mode, but I see no duration and no "custom" mode. Duration IS in the portal, but still no custom. Will I have a wat to select and randomize Lagoon, ReefCrest, and Long Pulse?
I suspect a lot will have to be changed (maybe it will be easy...) in order to incorporate the things we've done. However since it's all in the wizard it might be best to start fresh and go from there... just something to keep in mind.
Duration is only available on certain modes.
No custom with the wizard :(
If you are doing custom, you don't need the wizard :)
But he wants to utilize the DC Pump portal section... I think it be easiest to start with that fresh from the wizard and add his custom stuff back in after. :)
Also, off topic, but I had no idea new code was pushed :) The sticky with the changelog doesn't show up in New Posts. Can you bump it in the future when a new release is made. :D
Paulturner911
I think Im going to stick with what Im running and possibly (with Lees help) come up with a way to randomize specific modes. I dont see much difference in the DC or the Vortec menus.....What would I gain in changing?
I just looked at the changes made in the libraries. It will be much easier to do everything with that because your whole if else block to look at the functions is all part of the ReefAngel class now.
You've got a lot of custom stuff so yeah, for you it might be easier to leave it for now, once I see how the new stuff is used, I can help you transition to it.
The main benefit will be that since you don't have a RF module, your using the memory locations, but your not tracking changes to speed duration and mode in the portal charts. (i.e. You can't do a chart on RFS for instance (RFSpeed). You can't even look at what that variable has been set for because the portal doesn't track memory addresses.
With the new libraries, the DCS (DC Speed) is now reported by /r99 and will be part of the XML sent to the portal, so you'll be able to view exactly what state your DC Pump is in and not just look at the PWMD output.
Also, since we'll be doing random modes each day you can track what your DCD value looks like to know which mode your controller chose that day :) Lots of cool things.
Paulturner911
I like the idea of being able to identify what mode it IS or WAS in!! Please keep me posted.
Paulturner911
LOL, back in DEFAULT. UGH!!
Ill wait it out a few, and dabble in the wizard to see what I can do on my own this weekend..... I should be able to get my basic stuff back in after running the wizard, then Ill work on the WP40 stuff.
Paulturner911
Ive run the wizard and stuck all of the custom in that I thought would not conflict. Basically everything with the exception of the custom feed mode and the custom randomized WP mode. The following was what I would like modified to work with the DC
if (!feeding)
feeding=true;
} else {
feeding=false;
//IDK Rimai Posted
int minOffset=25;
int maxOffset=25;
static int rmode;
if (mode==12) {
mode=rmode;
// Constant
// Lagoon
// Reef Crest
// Short Pulse
// Long Pulse
// Tidal Swell
// Smart_NTM
} else {
// Default
Paulturner911
Here is my current DC CODE
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.DayLights( Port1 ); // Return Pump
ReefAngel.StandardFan( Port2 ); // Canopy Fans
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
//Port 6 NOT USED (Possibly Skimmer)
ReefAngel.DayLights( Port7 ); // MH 1
ReefAngel.DayLights( Port8 ); //MH2
//Over Flow Protection
//ATO Protection
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
