wifi attachment causing problems
bencollinz
Post by bencollinz »
This has been working fine for the past, at least 3 months. Now whenever I attach the wifi to the head unit the following happens....
[youtube]http://www.youtube.com/watch?v=nJ71dvUF-Zs[/youtube]
The cable is inserted correctly at both ends. If I leave it unplugged the head unit is fine forever.
Are there any troubleshooting steps I can take? Before the head unit goes into that infinite loop the wifi attachment does light up green and works via the portal/android phone, very briefly. Then the wifi flashes an orange LED and goes into the loop in the video.
my current code
        #define Heater      1
        #define Return      2
        #define Skimmer     3
        #define Vortech1    5
        #define Vortech2    6
        #define ATO         7
    byte vtechmode;
            ReefAngel.FeedingModePorts = Port2Bit;
            ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit;
            ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port7Bit | Port4Bit | Port5Bit | Port6Bit;
            ReefAngel.Relay.On( Port2 );
            ReefAngel.Relay.On( Port5 );
      // Hardcode calibrations
      ReefAngel.PHMin=576; // PH7.0
      ReefAngel.PHMax=842; // PH10.0
            ReefAngel.SalMax=3000; // 35ppt
            ReefAngel.StandardHeater( Port1,796,802 );
            StandardHeater2( Port3,760,770 );
            ReefAngel.WaterLevelATO( Port7,120,50,52 );   // If water level less than 52, turn on auto top off relay; else, keep it off
            ReefAngel.PWM.SetChannel( 0,PWMSlope(21,30,8,0,15,31,10,15) );
            // ReefAngel.SingleATOLow(Port2);
            if ( ReefAngel.HighATO.IsActive())
              ReefAngel.Relay.On(Port2);
              ReefAngel.Relay.Off(Port2);
      if (hour() >=8 && hour() < 21)
        if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0);
        ReefAngel.RF.UseMemory=true;
        ReefAngel.Relay.Off(Port8);
        ReefAngel.RF.UseMemory=false;
        ReefAngel.Relay.On(Port8);
            ReefAngel.Portal( "bencollinz" );
          char text[7];
            ReefAngel.LCD.DrawDate( 6, 2 );
      ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
      ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
      for (byte Left=93; Left < 133; Left+=10)
        ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, Left, "|");
        ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, Left, "|");
    ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
      ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
      if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
      else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
      else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
      else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
      else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
      else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
      else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
      else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
      ReefAngel.LCD.DrawText(0,255,10,30,"Temp");
      ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
      ReefAngel.LCD.DrawText(0,255,50,30,"Temp2");
      ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 50, 40, text, Num8x8);
      ReefAngel.LCD.DrawText(0,255,100,30,"pH");
      ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 40, text, Num8x8);
      ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
      ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
            ReefAngel.LCD.DrawOutletBox( 12, 77, TempRelay );
    // water level
        ReefAngel.LCD.DrawText(0,255,8,68,"WL:");
        ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 40, 68, ReefAngel.WaterLevel.GetLevel() );
        void StandardHeater2(byte HeaterRelay, int LowTemp, int HighTemp)
        if (ReefAngel.Params.Temp[T2_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
        if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
        if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
thank you in advance
Also, I did have a power outage that ended up frying 3 of my other expansions which have since been replaced. I'm really hoping this isn't the same case.
Re: wifi attachment causing problems
Can you communicate with the wifi module using putty?
bencollinz
rimai wrote:Can you communicate with the wifi module using putty?
tera term just repeats that over and over
putty you can see for yourself
what would you like me to try next?
bencollinz
and twice now it's gone into 'feeding mode' without any input from me. I'm really lost here. I've replaced EVERYTHING besides the relay box.
Those GET stuff is coming from your client software, I think.
Do you have the client running somewhere?
I don't see why it would cause that to the controller though.
But I can see you can connect with the wifi using putty just fine.
You have a relay expansion, right?
Can you try swapping those relay boxes?
bencollinz
rimai wrote:Those GET stuff is coming from your client software, I think.
the "get w" is from me just to see if it would respond.
I do not have the client running anywhere.
Yes, I have expansion. I will swap.
Did you want me to try anything else with the wifi module?
bencollinz
I swapped the relay box and no more wifi module issues. strange.
I haven't re-attached the box in question; however.
As soon as my son wakes up from his nap I will open up the relax box in question to see if I can see anything odd.
bencollinz
I opened the relay box in question and don't see anything odd...
any suggestions?
bencollinz
nevermind, just as I typed the last post it started doing that loop in the original video again.
What happens if you disable the client or gadget from polling data from the wifi??
bencollinz
rimai wrote:What happens if you disable the client or gadget from polling data from the wifi??
I'm not really sure what this means. The only thing that I use the wifi with is the portal or my phone(android) but nothing that runs separate on a PC. Sorry.
Well, the screen shot above tells me that there is something trying to connect to your RA repeatedly.
Do you know what it is?
bencollinz
rimai wrote:Well, the screen shot above tells me that there is something trying to connect to your RA repeatedly.
ok, you were correct. even though I didn't have the reef angel client open the listener process was still running. I ended that and no longer get anything in the tera term window unless I input a command.
where now?
in addition, with the wifi module plugged into the PC with the usbttl the green light is flashing steadily. I don't know if that means anything.
Do you still get the reboots on RA with the client shut down?
bencollinz
rimai wrote:Do you still get the reboots on RA with the client shut down?
yes, almost immediately.
Humm...
Maybe you need to send that wifi attachment back to be checked out.
PM me for details.
bencollinz
rimai wrote:Humm...
PM me for details.
Hey, I got your PM but before I send the wifi to you please take a look at the following video...
I noticed that if I plug in the wifi cable without the attachment it does this. Maybe that's supposed to be normal behavior? I wasn't sure.
I plug in the TTLUSB and it doesn't do this. You'll see in the video that I also plug in the cable WITH the wifi attached to it and it doesn't reboot immediately but inevitably it does (not shown in this video).
[youtube]http://www.youtube.com/watch?v=evdPKbO_y0o[/youtube]
So I got my old board out, which I 'thought was bad', and it does the same thing.
Is all of this just because of a bad cable?
No, by plugging just the cable, without the wifi attachment on the other end, will cause that behavior in the video.
The wifi must be connected on the other end or the cable must be disconnected.
bencollinz
rimai wrote:No, by plugging just the cable, without the wifi attachment on the other end, will cause that behavior in the video.
Ok, sending the wifi module to you right now! Thank you so much for your help. I know, I'm probably such a pain.
td7971
Post by td7971 »
I am late to this party. I have been fighting this same issue for the past two weeks. My unit was working great for the past four months. I installed a new salinity expansion. When I did this, I updated to the latest libraries. I noticed that the wizard put the following line in twice:
I see this in your sketch also. When I removed the second line, the rebooting was not as frequent. It still happens several times per day. Mine is very frustrating, I have my tank in my bedroom. When it reboots, the PWM takes the tank lights to 100% and then fades off. I don't like waking up to that every couple of hours.
I am leaning to a problem in the new libraries.
bencollinz
td7971 wrote:I am late to this party. I have been fighting this same issue for the past two weeks. My unit was working great for the past four months. I installed a new salinity expansion. When I did this, I updated to the latest libraries. I noticed that the wizard put the following line in twice:
you are correct. I never noticed that before. however, I can't confirm that that would matter or not and I don't have my wifi module to test it.
td7971
Post by td7971 »
I have tested running without the wifi unit. I have also tried rolling back to an older library (1.07). Nothing seems to work. It is a real pain when I was doing a water change, and everything kept coming back on. I am at a dead end as to what is causing this. I am going to unplug the PWM expansion and if that is not it, I will unplug the salinity expansion.
bencollinz
td7971 wrote:I have tested running without the wifi unit. I have also tried rolling back to an older library (1.07). Nothing seems to work. It is a real pain when I was doing a water change, and everything kept coming back on. I am at a dead end as to what is causing this. I am going to unplug the PWM expansion and if that is not it, I will unplug the salinity expansion.
I unplugged everything at one point including ph and temp except the wifi and it still did it.
Roberto has had my wifi for a week testing it and he found nothing wrong with it. so I'm lost as well.
bencollinz
got my wifi back today, plugged it in and now this...
[youtube]http://www.youtube.com/watch?v=21QnDxmbj3s[/youtube]
it locks up everything to the point it won't run/turn on/off things that should be.
it keeps whatever was happening at that moment running until I press the joystick or reboot.
PLEASE HELP!
current code
    #define HeaterTk2   1
    #define Return      2
    #define Heater      3
    #define Skimmer     4
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
    #define Sump Light  8
byte vtechmode;
        // Use T2 probe as temperature and overheat functions
        ReefAngel.Relay.On( Port4 );
    vtechmode=InternalMemory.RFMode_read();
    static unsigned long feeding;
        StandardHeater1( Port3,760,770 );
        StandardHeater2( Port1,796,802 );
        ReefAngel.WaterLevelATO( Port7,120,72,74 );
        ReefAngel.PWM.SetChannel( 0,PWMSlope(21,30,4,0,15,31,10,0) );
        ReefAngel.PWM.SetChannel( 1,PWMSlope(8,30,21,30,15,50,10,0) );
        ReefAngel.PWM.SetChannel( 2,PWMSlope(8,30,21,30,15,90,10,0) );
        ReefAngel.PWM.SetChannel( 3,PWMSlope(8,30,21,30,15,50,10,0) );
        ReefAngel.PWM.SetChannel( 4,PWMSlope(8,30,21,30,15,50,10,0) );
 if (hour() >=8 && hour() < 22)
             feeding=now();
            if (now()-feeding > 1 && now()-feeding < 3600) { // 1 second after feeding mode until 60 minutes after feeding mode.
    ReefAngel.RF.SetMode(Smart_NTM,65,5);
      char text[7];
      // Relay Expansion
// water level
    void StandardHeater1(byte HeaterRelay, int LowTemp, int HighTemp)
    if (ReefAngel.Params.Temp[T1_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
    if (ReefAngel.Params.Temp[T1_PROBE] <= LowTemp && ReefAngel.Params.Temp[T1_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
    if (ReefAngel.Params.Temp[T1_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
I tested that module for 3 uninterrupted days without a problem.
So, I'm confident the problem is not the wifi module.
It can only be something that is happening in your setup.
I would suggest you disconnect everything and go plain vanilla with just the controller.
Then add just the wifi.
And then go plugging one thing at a time.
rossbryant1956
Post by rossbryant1956 »
I experienced this same thing two nights ago. See my other posts re: berserk pH ports. I am now in the process of disassembling and reassembling everything. Strange that it is effecting some many of us at the same time...hard to blame everyone's hardware. Thx to all.
bencollinz
I changed my code to this. unplugged everything except dimming and wifi.
    ReefAngel.Relay.On( Port3 );
    ReefAngel.StandardLights( Port8,22,0,6,0 );
    int x,y;
    ReefAngel.LCD.DrawMonitor( 15, 15, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 15, ReefAngel.Params );
    ReefAngel.LCD.DrawOutletBox( 12, 56, TempRelay );
bencollinz
so far no reboots or red LED, that I've noticed.
bencollinz
trying this now
        InternalMemory.OverheatTemp_write( 829 );
        int x,y;
added 2nd tank heater control back. as well as plugging 2nd temp probe back in.
bencollinz
I believe I have figured this out...everything has been running fine on the plain code above and when I got home from work I reconnected the expansion hub and only the dimming to the expansion.
after at most, 5 minutes I got the blinking red LED and the RA froze. so while I was moving wires around I noticed something.
[youtube]http://www.youtube.com/watch?v=--VFu3xCU_c[/youtube]
I tried a different usb cable and it does the same thing. It appears the micro port on the expansion hub is bad.
any thoughts?
