Switch Relays (no power)
wideawake
Post by wideawake »
Hi there,
Just got my RA controller and I must say that I'm excited to get it running on my tank. However, I'm trying to blend it into my setup as efficient as possible without changing too much of my wiring.
Currently my return pumps (2 pumps) and skimmer pumps (2 pumps) are connected to a wall socket.
wall socket
wall socket
I turn them on and off using a light switch. The switch will complete the circuit for the wall sockets. It is wired directly to the room's power distribution box.
switch
switch
I have something like this from my previous Arduino projects, which is a Sainsmart Solid state relay. What it does is
also complete the circuit when the instruction is given to it, similar to the one we have in the relay.
SSR
SSR
The question is, how can I integrate this with the RA controller?
Thanks.
Re: Switch Relays (no power)
You need an I2C expander IC to control your board.
wideawake
Post by wideawake »
Hmm... Now I realized I should have bought the ones with I2C controller built in...
So if I have one of those, it's just a matter of connecting the 3 cables somewhere and giving it an I2C address or something?
Sent from my Galaxy Note II using Tapatalk 4 Beta
Yes.
The I2C bus is easily accessible on the USB port of the relay box.
wideawake
Post by wideawake »
Will something like this work?
http://www.ebay.com/itm/4-RELAY-MODULE- ... 2c64f48144
I think so, but I can't see the schematics.
What concerns me is the lack of diode on the relay.
http://electronicsclub.info/relays.htm
wideawake
Post by wideawake »
Yes it is.
In fact, I just added support for that same chipset into the libraries yesterday.
It will be released in the next patch.
Then, just make sure to set the address to 0x27
wideawake
Post by wideawake »
Sweet. Now to figure out how to be able to use it. Haha
Sent from my GT-N7100 using Tapatalk 4 Beta
Piper
Post by Piper »
That's pretty cool! Will that work in addition to the current I/O module?
~Charlie
No :(
Oh wait.....
You can do something different instead, though.
You can use a wall wart powering a small relay that is connected to the I/O module.
Your RA system uses UPS powered outlet and the wall wart uses grid outlet.
You got the idea?
wideawake
Post by wideawake »
rimai wrote:Yes it is.
Hi Roberto,
I've recently received the I2C controllers. You mentioned that support for this is in the next patch. How can I download the libraries before the official release? And I'm hoping there is some kind of documentation on how to address the modules.
Thanks.
It's in the dev branch of the github:
https://github.com/reefangel/Libraries/tree/dev
