V1.0.9 custom dc pump setting
jjdezek
Under the list of DC pump settings is a custom setting. What is this for, can you make a custom code to load in that space?
Re: V1.0.9 custom dc pump setting
Yeah it's a hook so you can define your own mode. Whether it would be a time based sync or a custom function, it will let you write whatever you want and choose it from the portal or go back to another mode later.
jjdezek
Ok if you write a custome code where would you place it to access it under the costom option?
In the area where it says insert custom code here
http://forum.reefangel.com/viewtopic.php?p=28394#p28394
jjdezek
