what do i put in my code to turn on channels on my dimmer expansion when i go to lights on mode??
thanks.
pwm expansion/lights on...
pandimus
Re: pwm expansion/lights on...
Try this:
if (bitRead(Flags,LightsOnFlag))
ReefAngel.PWM.SetChannel(0,100);
bubbles
Where do I read the value for "Flags" from?
rimai wrote:Try this:Code: Select all
bitRead(Flags,LightsOnFlag);
The changelog has what each bit is for:
http://forum.reefangel.com/viewtopic.php?f=7&t=1473
You also probably need to say ReefAngel.Flags and not just Flags btw.
bubbles
Perfect, thanks a lot.lnevo wrote:You also probably need to say ReefAngel.Flags and not just Flags btw.
