how to revert back to older librarys?
pandimus
Post by pandimus »
Trying to upload new code, and keep getting sketch too big error. Tried older code that loaded fine, still getting error only difference is new librarys. So.. how do i go back? ive already downloaded the old librarys.. I put them in the reefangel folder, but it still does not recognize them...
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
    ReefAngel.Relay.On( Port5 );
    ReefAngel.StandardHeater( Port1 );
    ReefAngel.DayLights( Port2 );
    ReefAngel.StandardFan( Port3 );
    ReefAngel.DayLights( Port4 );
    ReefAngel.DayLights( Port6 );
    ReefAngel.DosingPumpRepeat1( Port7 );
    ReefAngel.DosingPumpRepeat2( Port8 );
    ReefAngel.PWM.Channel0PWMSlope();
    ReefAngel.Portal( "pandimus" );
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Custom Main Screen
Dimming Expansion Module
Simple Menu
Binary sketch size: 32,556 bytes (of a 32,256 byte maximum)
processing.app.debug.RunnerException: Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
at processing.app.Sketch.size(Sketch.java:1844)
at processing.app.Sketch.build(Sketch.java:1775)
at processing.app.Sketch.build(Sketch.java:1750)
at processing.app.Editor$DefaultRunHandler.run(Editor.java:1867)
at java.lang.Thread.run(Thread.java:619)
Re: how to revert back to older librarys?
You will need to delete the existing libraries off of your computer. Usually these are stored in the ~/Documents/Arduino/libraries folder.
  • Delete existing libraries from ~/Documents/Arduino/libraries
  • Then download the version that you want from here: https://github.com/reefangel/Libraries/tags
  • Unzip the zip file and rename it from Libraries-VERSION to just be libraries
  • Place that folder in your Arduino folder
  • Restart Arduino and then check the version.
That's how you can downgrade / revert back to older libraries
pandimus
Post by pandimus »
Thanks..worked great.I was moving wrong library's..
Sent from my SCH-I535 using Tapatalk 4 Beta
