new version issue
jjdezek
new version issue
I downloaded the latest version and redid my wizard and coding for my RA went into the portal to do the wp40 set up and no matter what i do it stay at 20 on both. whats up with that?
jjdezek
Re: new version issue
I had to put the codes back in the custom area to get it to work. I was told with the new version you could toggle between wave modes in the portal. is this possible now?
#define NUMBERS_8x16
ReefAngel.LCD.DrawDate(6, 112);
ReefAngel.LCD.DrawText(COLOR_INDIGO, COLOR_WHITE,25,5, "Jeremy's Reef");
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
ReefAngel.WaterChangePorts = Port1Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardATO( Port1,60 );
ReefAngel.StandardLights( Port3,18,0,10,0 );
ReefAngel.WavemakerRandom( Port5,30,100 );
ReefAngel.WavemakerRandom( Port6,30,100 );
ReefAngel.StandardHeater( Port7,752,755 );
if (hour()>=8 && hour()<12)
ReefAngel.PWM.SetDaylight( ReefCrestMode(100,20,true) ); // ReefCrest at 100% +/- 20% on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(100,20,false) ); // ReefCrest at 100% +/- 20% on anti-sync mode
else if (hour()>=12 && hour()<18)
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,100,200,true) ); // Short pulse at 100% with 200ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,100,200,false) ); // Short pulse at 100% with 200ms pulse on anti-sync mode
ReefAngel.PWM.SetDaylight( LongPulseMode(0,100,10,true) ); // Long pulse at 100% with 10s pulse on sync mode
ReefAngel.PWM.SetActinic( LongPulseMode(0,100,10,false) ); // Long pulse at 6100% with 10s pulse on anti-sync mode
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
ReefAngel.Portal( "jjdezek" );
void DrawParamsa(int x, int y){
char buf[16];
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x+40,y+10,"WP40L:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+78, y+10,1);
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+40,y+20,"WP40R:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+78, y+20,1);
void DrawParams(int x, int y) {
char buf[16];
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+5,y,"Temp:");
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+80, y, "PH:");
// Temp and PH
y+=10;
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+80, y, buf, Num8x16);
y+=5;
void DrawStatus(int x, int y) {
int t=x;
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"High",Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,y,"Low",Font8x16);
ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_GREEN);
} else {
ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_RED);
if (ReefAngel.LowATO.IsActive()) {
ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_GREEN);
} else {
ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_RED);
Yes, but you need to generate a code with the wizard and make sure you check mark DC Pump on the attachment list.
jjdezek
ok found it. thanks. i was looking under the dimming portion for a jeabo option. its earlier in the wizard.
jjdezek
jjdezek
Ok I set it up for reefcrest at 100% and duration of 9 and my power head is not working now
jjdezek
its running now but im not able to switch from one mode to another in the portal. it just stays in the reefcrest mode. also i set it at 100% yet it will go up to 120% on the display and in the portal. is it really running that high?
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
ReefAngel.Wavemaker( Port5,60 );
ReefAngel.Wavemaker( Port6,60 );
ReefAngel.StandardHeater( Port7,751,761 );
ReefAngel.DCPump.SetMode( ReefCrest,100,10 );
ReefAngel.DCPump.DaylightChannel = AntiSync;
ReefAngel.DCPump.ExpansionChannel[0] = None;
char buf[16];
char buf[16];
// Temp and PH
y+=10;
y+=5;
int t=x;
} else {
} else {
Your code is hard coding the mode and is disabling memory.
Take out those two lines...the one saying UseMemory=false; and the one after setting it to ReefCrestMode.
jjdezek
jjdezek
are you talking about this part of the code?
jjdezek
ok done but it still seems like its not working correctly. i can switch it between reefcrest and tidal swell but cant get it to take nutrient export or a few others. its like sometimes it works and other times it wont.
jjdezek
Poiromaniax
just on the duration note - will the duration affect Vortech pump modes as well? Say if i want to run the default Vortech ReefCrest mode, do i make duration 0 or leave it as 10?
Poiromaniax
