Poiromaniax
Posts: 180 Joined: Thu Apr 05, 2012 6:20 am
Post
by Poiromaniax » Fri Jun 28, 2013 5:48 am
Hey,
Just want to check something - I have installed my float switches in the tank... Shouldnt the bottom float switch be "floating"?
Also, do i plug the switches into the ports located to the left of the PH input? does it matter which one i plug where?
Posts: 5422 Joined: Fri Jul 20, 2012 9:42 am
Post
by lnevo » Fri Jun 28, 2013 5:57 am
Looks like its stuck...if its under water it should float in that orientation. The left port is the low and the right is high i believe.
Poiromaniax
Post
by Poiromaniax » Fri Jun 28, 2013 6:21 am
lnevo wrote: Looks like its stuck...if its under water it should float in that orientation. The left port is the low and the right is high i believe.
Thanks bro,
I can't remember if I checked to see if it was stuck or not.
Will do when I get home anyway
Posts: 12857 Joined: Fri Mar 18, 2011 6:47 pm
Post
by rimai » Fri Jun 28, 2013 8:02 am
You can't use magnetic holders.
There is a magnet inside of the float switch and the holder's magnet is too strong it will cause the float to be stuck by attraction or repulsion.
Post
by lnevo » Fri Jun 28, 2013 8:10 am
Ahh good point... and I was thinking that mount was so nice
Poiromaniax
Post
by Poiromaniax » Sat Jun 29, 2013 9:17 am
rimai wrote: You can't use magnetic holders.
Oh damn
How else are guys mounting their switches?
The magnets in that probe holder are pretty strong
Maybe I can rig up something with eggcrate.....
Post
by lnevo » Sat Jun 29, 2013 9:39 am
I bought some acrylic float switch brackets on ebay..
bubbles
Posts: 50 Joined: Wed Feb 20, 2013 3:05 pm
Post
by bubbles » Sat Jun 29, 2013 1:35 pm
Small tupperware container with a couple of small holes in it. Stops the switches tripping when there's a bit of sloshing in the sump.
Poiromaniax
Post
by Poiromaniax » Sun Jun 30, 2013 12:28 am
lnevo wrote: I bought some acrylic float switch brackets on ebay..
That be a good plan - I'm gonna look into this. The only issue is that I live in S.A and not everyone will ship here
bubbles wrote: Small tupperware container with a couple of small holes in it. Stops the switches tripping when there's a bit of sloshing in the sump.
Thanks bubbles, I'm struggling to visualize it. Do you maybe have a pic?
