Looking forward to hearing what you guys have to say
PaulTurner911 Code
Paulturner911
Re: PaulTurner911 Code
I went ahead and put the night mode in thinking it may work, but I was wrong....
Paul,
Thats not from the latest code....i know because i streamlined your feeding mode code and its thats not there, plus you didn't post the night mode portion.
And we need roberto to add custom mode to the portal *cough* *cough* otherwise you'll still have to activate the custom mode from memory manually..
I'll see what i can throw together tomorrow...
Paulturner911
You are right! I grabbed that from my OP in the thread...
Its pretty cool to see the DC Pump on the dashboard, but it doesnt show what percentage it is running at in that section, it does show above in the PWM though.
Last edited by Paulturner911 on Mon Jun 24, 2013 11:42 am, edited 1 time in total.
Paulturner911
Removed to clean up this thread
Last edited by Paulturner911 on Mon Jun 24, 2013 11:43 am, edited 1 time in total.
Try this:
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit | Port8Bit;
ReefAngel.DayLights( Port1 ); // Return Pump
ReefAngel.StandardFan( Port2 ); // Canopy Fans
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
//Port 6 NOT USED (Possibly Skimmer)
ReefAngel.DayLights( Port7 ); // MH 1
ReefAngel.DayLights( Port8 ); //MH 2
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 50sec @ 8pm-12pm (every 15min)
if (hour() >=20 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<50);
//Kalk Stir 12pm-1pm
if (hour() >=12 & hour() < 13)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Off(Port5);
///// Place your custom code below here
static int rmode;
byte modes[] = { ReefCrest, TidalSwell, ShortPulse, NutrientTransport };
changeMode=false;
// Are we in custom mode
if (ReefAngel.DCPump.Mode==11) {
ReefAngel.DCPump.UseMemory=false; // We are going to override the memory (which is currently set to 11..)
} else {
ReefAngel.DCPump.UseMemory=true;
static unsigned long feeding;
feeding = now();
// keep wavemakers off for first 30 minutes of feeding mode.
if (now()-feeding<=1800) { // 30 minutes after
ReefAngel.DCPump.Speed=0;
} else if (now()-feeding<=(1800+3600)) { // // First 30 minutes pump is off.. next 60 minutes will be in NTM
// Add night mode (constant 30%)
if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY >=81000) { // Time is before 8:30am and after 10:30pm
ReefAngel.DCPump.Speed=30;
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Paulturner911
Thank YOU SIR!!!
In order to add and remove modes, do I simply type and or remove them in the following section?
byte modes[] = { ReefCrest, TidalSwell, ShortPulse, xxxxxxxx, NutrientTransport };
Could you give a quick explanation of what tidal swell is?
Paulturner911
I'm having an issue with the feedmode, the wp is not turning to NTM at 1800 on the countdown. It's not turning back on once the 3600s times out either. I'm not sure the night mode is activating either, I uploaded late last night and it didn't run at 30.
Let me know what it did. I'll look again at the code...
Paulturner911
Its not activating NTP at 1800 and once the feedmode is complete (3600) the WP pump stays off. Basically once the feed mode is activate it turns the WP pump off until I goto the portal and select a mode other than NTM.
Paul I had an error in the feeding mode section that I fixed in my post above. Can you try it and let me know. If it doesn't work, I'll have to relook at the logic, but the error I had could have caused it to f up
Paulturner911
I'm having the same results with the newer code. The night mode doesn't activate and once feedmode has been activated the wp never resumes, it in theory should activate NTM at 1800s on the feedmode countdown. I'd appreciate any help, no rush!!!
I see where I went wrong. When we get to NTM mode we never reset the speed. Lots of other issues. I'm fairly confident in this rework. Please give it a try.
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
// 30 minutes after feeding mode. Pump is off
ReefAngel.DCPump.Speed=ReefAngel.DCPump.FeedingSpeed;
// First 30 minutes pump is off, Next 60 is NTM
ReefAngel.DCPump.Speed=InternalMemory.DCPumpSpeed_read(); // Resume previous speed
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
// Night mode (go to 30%)
ReefAngel.DCPump.Mode=modes[rmode]; // Set the mode to the random mode
} else {
feeding = now();
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Paulturner911
Awesome! Ill try tonight and let you know! I really appreciate the help Lee.
Thank You
Thank You
Paulturner911
I had to move
feeding = now();
ABOVE
b/c I was getting an error for feeding being undefined, when I switched them it worked.
However I am in the same boat, or even worse with the NTP/Feedmode. It still does not activate at the 1800s mark nor after feedmode has timed out. The only difference is before I could go in the portal and activate any mode, now it is unresponsive. Meaning the WP will not run in any mode right now.....Please help
feeding = now();
ABOVE
Well go back to your older code..gonna take me a while to figure it out.
Paulturner911
It eventually turned back on, just not in or right after feedmode. I looked in the portal after feedmode timed out and it read NTM instead of custom, BUT it read a speed of ZERO at that time. Now its seems to be running "night mode, in NTM" at 30 in stead of nightmode constant 30....its pulsing. Keep me posted, Thanks
Oh ok thats cool..we can figure some of that out...
Also just an fyi can you confirm your feeding mode time...how long your return pump is off for..
Right now it goes:
Feeding mode start 00:00
Feeding mode finish 15:00???
Wavemaker at 0 till 45:00
Ntm at usual speed till 1:45
The extended wavemaker off used to be 30 minutes total but now its 45 minutes.. I can fix that but just making sure you are expecting the right thing.
Right now it goes:
So it looks like you reset your controller at around 3:30..mode was in NTM from that point on..which is part of your random rotation... At about 7:05 you went into feeding mode. Your speed was at 0 and mode still at NTM... until 8:14 when it went back to 60. You were still in NTM mode...now forced (ignoring custom mode) until 10:30 when night mode kicked in staying in NTM at 30%.
This is based on the charts below. Keep in mind 0 values do not show on the graph...but note the gap between 7:04 and 8:14.
Speed
http://forum.reefangel.com/status/chart ... filter=DCS
Mode
http://forum.reefangel.com/status/chart ... filter=DCM
So it looks like everything is working except the following which I've fixed below:
Change extension of feeding mode to 15 minutes so total duration is 30. Feel free to make the 900 back to 1800.
Fixed the timer issue you had as well...sorry bout that one.
Force night mode to Constant instead of whatever is default mode (NTM was today's mode.)
Speed
Mode
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
feeding = now();
if (now()-feeding<=900) {
} else if (now()-feeding<=(900+3600)) {
} else {
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Paulturner911
Sorry I didnt get back to you last night. I have feed mode set to 3600, thats when the return pumps should activate. I was wanting NTM to activate at 1800 in feed mode.
Feedmode activated:
Countdown timer now reads 3600 all pumps OFF
Countdown timer reads 1800 activate NTM for 60min
Feedmode complete activate return pumps and continue running NTM for 30min
It seems you have everything working, I was just misunderstanding the scheduling of it. Could you set the times to the above schedule? Thanks.
Feedmode activated:
I dont understand your scheduling...
For the record the timer stays at 0 during feeding mode so it doesn't start incrementing until feeding mode is over.
So whatever number is set is plus your feeding mode time already...
You want ntm running while your return pumps are off??? So confused..
If i recall we shortened feed mode to 15 minutes and extended the wavemaker time so that wavemakers were off for 30 minutes but returns kicked back on before. Once that was done we kicked in NTM. What you describe sounds way different
Paulturner911
I was wanting NTM to stir up uneaten food and what not then the return pump to turn on and remove from display tank. Ill shorten feed mode to 15 and run it, maybe Ill like your way better
Paulturner911
Its only showing a value since Saturday. I dont' see any reference to the Actinic channel in the last code posted... Your PWMD looks nice though
Is it possible you overrode it somewhere or changed something in your code?
Paulturner911
My WP40 seems to zero out at some point and I reboot the controller to get it working. After a few days, its at zero again. ANy help would be great.
Paulturner911
Revisiting this, I would like to switch the order in which the two pumps are activated. I WOULD like NTM to turn on 15min before the return pump comes on. The reason is when I spot feed my corals I feed heavy and the fish come back out once the pumps kick on to eat what's being stirred up. To recap when I activate my feedmode it runs for 15min with no flow, then 15min in to the NTM the returns should kick on.lnevo wrote:I dont understand your scheduling...
I think I could make it work by setting the mem loc for feed time to 30min and making some changes to:
I'm just not sure why it says 30min but 900 seconds in that section.?!
The way the whole feeding timer is written it will not work the way you want. I will need to rework the logic. Right now feeding always equals now during feeding mode. So any check on that number will not reflect how long into feeding mode you are to reenable the return pump. I'll have to re-add the static boolean so that we only update feeding once,.. Give me some time to work on it.l
lnevo wrote:
Changed extension of feeding mode to 15 minutes so total duration is 30. Feel free to make the 900 back to 1800.
