dosing pumps
nbelohlav
dosing pumps
someone explain to me how to get my dosing pumps to work on the schedule i want... right now i have them programmed to turn on every 240 minutes for 10 seconds and they havent turned on for two days... please help before i decide to sell everything.
nbelohlav
Re: dosing pumps
ill post it as soon as i get back from the gym... how do i get it off the controller?
nbelohlav
Re: dosing pumps
ReefAngel.FeedingModePorts = Port7Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port6Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.DayLights( Port2 );
ReefAngel.MoonLights( Port3 );
ReefAngel.Relay.DelayedOn( Port4 );
ReefAngel.Relay.Set( Port5, !ReefAngel.Relay.Status( Port1 ) );
ReefAngel.StandardHeater( Port6 );
ReefAngel.DosingPumpRepeat1( Box1_Port1 );
ReefAngel.DosingPumpRepeat2( Box1_Port2 );
ReefAngel.Portal( "nbelohlav" );
int x,y;
// Parameters
// Main Relay Box
// Relay Expansion
// Date and Time
i am pretty sure that this is what i saved at 2 am this morning....
int x,y;
// Parameters
// Main Relay Box
// Relay Expansion
// Date and Time
Re: dosing pumps
You are using internal memory.
There is no way to see your settings
How do you know it is not working?
Re: dosing pumps
For troubleshooting its best to go with a hard coded setting:
Try this
ReefAngel.DosingPumpRepeat(Box1_Port1, 0, 240, 10);
ReefAngel.DosingPumpRepeat(Box1_Port2, 5, 240, 10);
Try this
nbelohlav
Re: dosing pumps
rimai wrote:You are using internal memory.
cause the liquid level in my cal and alk jugs hasnt changed at all...
nbelohlav
Re: dosing pumps
lnevo wrote:For troubleshooting its best to go with a hard coded setting:
Try this
and where do i put that code?
Re: dosing pumps
In place of the lines where your other dosingpump lined are...
nbelohlav
Re: dosing pumps
alright i replaced what you said to... we will see if that works, i have them going into containers of their own to see if it works come the morning...lnevo wrote:In place of the lines where your other dosingpump lined are...
nbelohlav
Re: dosing pumps
well i believe that inserting that code worked as there was liquid in the containers when i checked them...
what is the portal interval for recording input? the portal still doesnt show that the relays were activated when they were...
Re: dosing pumps
The portal wont show it. 10 seconds is not enough time. It only logs every 5 minutes.
Re: dosing pumps
If you look through this thread http://forum.reefangel.com/viewtopic.php?f=12&t=3262 you can see what I did for kirkwood. There's some code I wrote for myself to switch to volume based dosing instead of time so it does all the calculations and also the code that was specific for kirkwood that logs the amount of time the dosers are on and logs it to the portal so he can track how much time exactly the pumps are on. I can help you implement it for yours if your interested.
