How gets lights on out of the preprogrammed timer.
Bo0sted_Rafi
I got my lights hooked in my pwm ports buts if I need to get the lights on for maintenance of something, how do I can gets on? I got my wifi attatchment and iPhone app working but I don't know how to do it. Another thing it's when the lights are on, if I get other ports of like moonlights or wavemakers, the lights get off too and I don't want that
- Sacohen
Re: How gets lights on out of the preprogrammed timer.
I don't know about the Iphone app because I have an Andriod, but main menu on the RA head unit has a menu that says Lights and you can turn them on or off from there.
Also from the Web Portal you can turn on any of the Ports by grabbing on them and dragging then to on or off.
In your code is lightsonport and lightsoffports.
It should be in the setup section. Take out the ones you dont want shutting the lights off from the lightsoffports and add a port that you want as the lights on port...
Im pretty sure that how it works...
Bo0sted_Rafi
In The HU menu i don't have that lights setup. Can I make a code I don't using to make if x port on, pwn on at 100% or something?
