temp adjustments
jjdezek
temp adjustments
Post by jjdezek »
I want to increase my temp setting so i went to the portal and changed the settings from 76 to 77 and checked on my iphone to see if it changed on there, which it did. the only problem is ive been watching the relays and the heater hasnt kicked on. i have the heater plugged into #7 im woundering if its been turning on at all. I initially set it up through the wizard but never watched to see if the heater kicked on. i know the temp would fluxuate but never got out of control. i dont see anything in my code for heater on off settings but i do see the over temp setting.
#define NUMBERS_8x16
ReefAngel.LCD.DrawDate(6, 112);
ReefAngel.LCD.DrawText(COLOR_INDIGO, COLOR_WHITE,25,5, "Jeremy's Reef");
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
    ReefAngel.WaterChangePorts = Port1Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardATO( Port1,60 );
    ReefAngel.StandardLights( Port3,18,0,10,0 );
    ReefAngel.Wavemaker( Port5,60 );
    ReefAngel.Wavemaker( Port6,60 );
    ReefAngel.StandardHeater( Port7,751,761 );
    ReefAngel.DCPump.DaylightChannel = AntiSync;
    ReefAngel.DCPump.ExpansionChannel[0] = None;
      if (ReefAngel.DCPump.Mode==Custom)
  ReefAngel.PWM.SetDaylight( ElseMode(70,30,true ));                     // ElseMode on sync mode, 70 +/- 30%
  ReefAngel.PWM.SetActinic( ElseMode(70,30,false ));                     // ElseMode on anti-sync mode, 70 +/- 30%
    ReefAngel.Portal( "jjdezek" );
void DrawParamsa(int x, int y){
char buf[16];
  ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x+40,y+10,"WP40L:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+78, y+10,1);
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+40,y+20,"WP40R:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+78, y+20,1);
void DrawParams(int x, int y) {
  char buf[16];
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+5,y,"Temp:");
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+80, y, "PH:");
  // Temp and PH
  y+=10;
  ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+80, y, buf, Num8x16);
  y+=5;
void DrawStatus(int x, int y) {
  int t=x;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"High",Font8x16);
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,y,"Low",Font8x16);
    ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_GREEN);
  } else {
    ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_RED);
  if (ReefAngel.LowATO.IsActive()) {
    ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_GREEN);
  } else {
    ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_RED);
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
Re: temp adjustments
Add ReefAngel.StandardHeater(Port7);
You dont' have it in there..
jjdezek
Post by jjdezek »
this is under the void loop
jjdezek
Post by jjdezek »
well i changed the numbers from 751,761 to 770,773 and the heater kicked on. why didnt it change it from the portal?
You are using hard coded settings.
If you want to change settings through the portal, you must use internal memory settings.
jjdezek
Post by jjdezek »
how would i do that coding?
Sorry I didn't see it when first scanning...
Either way, you want it to look like this to use Internal Memory.
lnevo wrote:ReefAngel.StandardHeater(Port7);
jjdezek
Post by jjdezek »
so would i just remove the ,751,761 from the code? do i add anything else to my code to make it work?
When you remove the values, it defaults to the memory settings... so that's all you gotta do.
jjdezek
Post by jjdezek »
ok thanks
