LED Dimming Module
fish76
LED Dimming Module
I currently have a BoostLED controller controlling my DIY LED setup. I'm able to on the fly to adjust intensity & duration for each of my individual LED channels (3 total) directly on the controller. I'm making my build list for a RA setup and I'm debating whether I should buy the dimming module or just use my existing BoostLED controller. Are you able to control intensities and duration directly on the RA controller? Or do you need to upload the script everytime you want to adjust either intensities/durations?
- Sacohen
Re: LED Dimming Module
I'm not sure of the answer, but I'm interested too, so I'm tagging along.
topjimmy
You can control them via the portal if you have the wifi adapter.
Edit: Well I can control mine, but they are a DIY set up. I guess it would depend on the type of driver they use and how it does dimming.
- Sacohen
topjimmy can you adjust the percentage that they are on IE change from 50 to 75% or is it just an on/off?
You can adjust percentage of start and end of the slope/parabola in the portal as long as you are using internal memory.
You can also use the android app to change the internal memory which would change the % of each channel.
Hopefully in the next update or two, Curt will have implemented the newest addition to the libraries I release last patch, which would let you override the % at any give time with the android app too
- Sacohen
Thank you Roberto.
I knew there was a way, but I forgot about doing it through the internal memory.
fish76
My DIY setup is w/PWM meanwell drivers and I intend to get the wi-fi moduletopjimmy wrote:You can control them via the portal if you have the wifi adapter.
Sorry for my ingorance since I'm just learning up on the RA, but what does it mean when you say "portal" and "internal memory"? Does that mean it can be changed via the web-based interface? To be able to change the intensity percentages/start-stop settings on the fly, is that custom coding that needs to be written or is it a default feature using the standard RA wizard to generate the code?rimai wrote:You can adjust percentage of start and end of the slope/parabola in the portal as long as you are using internal memory.
Will it eventually work with the iPhone app also?rimai wrote:You can also use the android app to change the internal memory which would change the % of each channel.
Portal: http://forum.reefangel.com/portal.php
You won't be able to access the internal memory section though. You need to have a controller to be able to access that section.
The wizard generates all the code you would need to change the settings through the portal.
fish76
Thanks Roberto, very cool. Just so I understand (sorry), based on that screen, only % can be changed and not start/stop times then?rimai wrote:Portal: http://forum.reefangel.com/portal.php
You can do all of it
turn on/off time and start/end percentage and duration of slope.
It's all there
It's all there
fish76
Sweet! Looks like that module will be added to the listrimai wrote:You can do all of it
It's all there
