Just installed the expansion module and relay expansion. How do I get the portal to recognize my new (8) ports?
my code:
//// Port 1 Heater
//// Port 2 ATO pump
//// Port 3 Reactor Pump
//// Port 4 Protien Skimmer
//// Port 5 Return Pump
//// Port 6 Wavemaker
//// Port 7 UV Sterilizer
//// BOX 1 PORT 8 Fuge Light
//// Always on - Lights & Salinity Module
#define Heater Port1
#define Topoff Port2
#define Reactor Port3
#define Skimmer Port4
#define Return Port5
#define Wave Port6
#define UVlight Port7
#define Fugelight Box1_Port8
#define FugelightBit 2<<7
#define UVlightBit 1<<6
#define WaveBit 1<<5
#define ReturnBit 1<<4
#define SkimmerBit 1<<3
#define ReactorBit 1<<2
#define TopoffBit 1<<1
#define HeaterBit 1<<0
static byte wpMode;
static byte wpWavStr;
static byte wpWavOff;
ReefAngel.FeedingModePorts = TopoffBit | ReactorBit | SkimmerBit | ReturnBit | UVlightBit;
ReefAngel.WaterChangePorts = HeaterBit | TopoffBit | ReactorBit | SkimmerBit | ReturnBit | WaveBit | UVlightBit;
ReefAngel.LightsOnPorts = FugelightBit;
ReefAngel.OverheatShutoffPorts = HeaterBit | TopoffBit | ReactorBit | SkimmerBit | ReturnBit | WaveBit | UVlightBit;
// Use T1 (SUMP) probe as temperature and overheat functions
ReefAngel.Relay.On( Return );
ReefAngel.Relay.On( Reactor );
ReefAngel.Relay.On( Wave );
ReefAngel.StandardHeater( Heater );
ReefAngel.StandardATO( Topoff );
ReefAngel.MoonLights( Fugelight );
ReefAngel.LCD.DrawText(0,255,20,80,"Joe's Reef Tank");
ReefAngel.Relay.DelayedOn(Skimmer,2);
ReefAngel.Relay.DelayedOn(UVlight,1);
ReefAngel.DCPump.FeedingSpeed=30;
//if (ReefAngel.DCPump.Mode==Custom) ReefAngel.DCPump.UseMemory = false;
//else ReefAngel.DCPump.UseMemory = true;
// Custom Wave Routine
if (ReefAngel.DCPump.Mode==Custom) {
// set the wpMode
if ( (hour() >= 5) && (hour() < 8) ) wpMode=1; // from 5am - 8am
if ( (hour() >= 8) && (hour() < 11) ) wpMode=2; // from 8am - 11am
if ( (hour() >= 11) && (hour() < 14) ) wpMode=3; // from 11a - 2pm
if ( (hour() >= 14) && (hour() < 17) ) wpMode=2; // from 2pm - 5pm
if ( (hour() >= 17) && (hour() < 20) ) wpMode=1; // from 5pm - 8pm
if ( (hour() >= 20) && (hour() < 23) ) wpMode=2; // from 8pm - 11p
if ( (hour() >= 23) && (hour() < 2) ) wpMode=3; // from 11pm - 2am
if ( (hour() >= 2) && (hour() < 5) ) wpMode=2; // from 2am - 5am
if (wpMode=1) wpWavStr=45;
if (wpMode=2) wpWavStr=50;
if (wpMode=3) wpWavStr=55;
//Set the Wave OffSet
wpWavOff=12;
//if (ReefAngel.DisplayedMenu==FEEDING_MODE) ReefAngel.PWM.SetDaylight(30);
//else
ReefAngel.PWM.SetDaylight( ReefCrestMode(wpWavStr,wpWavOff,true) );
ReefAngel.PWM.SetActinic(wpWavStr);
// end Custom Wave Routine
// Only turn on UV Sterilizer between 11pm and 5am
if ( (hour() >= 5) && (hour() < 23) ) // from 5a - 11p
ReefAngel.Relay.Off(UVlight);
else ReefAngel.Relay.On(UVlight);
ReefAngel.Portal( "Smotz" );
// Parameters
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 90, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 102, TempRelay );
// Date and Time
//draw the mode on the screen
char buf[16];
if (ReefAngel.DisplayedMenu==FEEDING_MODE) sprintf(buf,"Pumps at %d%%",ReefAngel.DCPump.FeedingSpeed);
else sprintf(buf,"RC %d%% +/- %d%%",wpWavStr,wpWavOff);
ReefAngel.LCD.DrawText(0,255,15,52,buf);
