Portal not showing correct info
Related to the Portal
ganjero
Post by ganjero »
Portal is not showing the correct info. It shows a bunch of relay boxes and other stuff I dont have. Banner doesnt work either.
Reef Angel wifi address: 173.6xxxxxx:2000
My reefangelid:
ganjero
Connection Status:
Ready
Last Update:
Sun Jul 14 12:56:20 2013
Displaying data from:
Reef Angel Controller (live)
Re: Portal not showing correct info
Looks like the banner is working now.
It was missing the initial labels. I forced them in the database for you.
Are you talking about relays 11 through 18?
ganjero
Post by ganjero »
Thanks, it seems the portal is working fine too; it was showing like I had 8 extra relay bars, voretch info, etc., stuff I did not have. Why do the relays skip 9 & 10?
ganjero
Post by ganjero »
It's happening again (showing 8 relay boxes and all possible expansion attachments). is it something I'm doing?
I have been working in getting a custom mode on my jebao and feeding modes for them but cant get them to work and I'm not sure if that is messing my portal too.
I want his mode for the jebao flow:
static unsigned long LastChange=millis(); // Set the inital time that the last change occurred
static int Delay = random( 500, 3000); // Set the initial delay
static int NewSpeed = MidPoint; // Set the initial speed
static int AntiSpeed = MidPoint; // Set the initial anti sync speed
if ((millis()-LastChange) > Delay) // Check if the delay has elapsed
Delay=random(500,5000); // If so, come up with a new delay
int ChangeUp = random(Offset); // Amount to go up or down
if (random(100)<50) // 50/50 chance of speed going up or going down
LastChange=millis(); // Reset the time of the last change
if (WaveSync)
return NewSpeed;
return AntiSpeed;
and I want this for the feed modes
static StartFeeding=0;
StartFeeding=now(); // if we entered feeding mode, register what time it was.
if (now()-StartFeeding > 1800 && now()-StartFeeding < 5400) // if feeding started between 1800 and 5400 seconds
ReefAngel.PWM.SetActinic(100);
ReefAngel.PWM.SetActinic(30);
and this is my current code:
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <ReefAngel.h>
////// Place global variable code below here
////// Place global variable code above here
    ReefAngel.FeedingModePorts = Port7Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port3Bit;
    ReefAngel.LightsOnPorts = Port1Bit | Port4Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit;
    InternalMemory.OverheatTemp_write( 851 );
      static time_t StartFeeding=0;
    ReefAngel.StandardLights( Port1,14,0,19,0 );
    ReefAngel.StandardLights( Port2,15,0,20,0 );
    ReefAngel.StandardLights( Port3,19,55,22,0 );
    ReefAngel.StandardLights( Port4,14,0,22,15 );
    ReefAngel.StandardHeater( Port5,780,785 );
    ReefAngel.StandardFan( Port6,780,800 );
    ReefAngel.Relay.DelayedOn( Port7,60 );
    ReefAngel.StandardLights( Box1_Port1,22,0,16,0 );
      if (ReefAngel.DCPump.Mode==Custom)
  ReefAngel.PWM.SetDaylight( ElseMode(70,30,true )); // ElseMode on sync mode, 70 +/- 30%
    ReefAngel.Portal( "ganjero" );
    int x,y;
    // Parameters
#if defined DisplayLEDPWM && ! defined RemoveAllLights
#else // defined DisplayLEDPWM && ! defined RemoveAllLights
#endif // defined DisplayLEDPWM && ! defined RemoveAllLights
    // Main Relay Box
    TempRelay &= ReefAngel.Relay.RelayMaskOff;
    TempRelay |= ReefAngel.Relay.RelayMaskOn;
    // Relay Expansion
    TempRelay = ReefAngel.Relay.RelayDataE[0];
    TempRelay &= ReefAngel.Relay.RelayMaskOffE[0];
    TempRelay |= ReefAngel.Relay.RelayMaskOnE[0];
    // Date and Time
      if (WaveSync)
        return NewSpeed;
        return AntiSpeed;
Can you try a different browser?
ganjero
Post by ganjero »
I changed the code and that seem to fixed it, I could not get the elsemode posted above to work, I'm not sure where the error was ( I would like if someone help me find it). For now I'm using the reefcrest mode, the variable speed in the portal shows on the pwm channels which is fine but how do I get to show it in the DC Pump area?
This is the code I'm using now...O left the elsemode code in there until I figure out how to use it.
        ReefAngel.PWM.SetActinic(45);
    ReefAngel.Relay.On( Box1_Port1);
    ReefAngel.StandardLights( Box1_Port5,22,0,16,0 );
    ReefAngel.PWM.SetDaylight( ReefCrestMode(70,30,true) ); // ReefCrest at 70% +/- 30% on sync mode
    int x,y;
    // Parameters
    // Main Relay Box
    // Relay Expansion
    // Date and Time
      if (WaveSync)
        return NewSpeed;
        return AntiSpeed;
I think you need this:
ganjero
Post by ganjero »
rimai wrote:I think you need this:
Replaced false with true but nothing changed.
ganjero
Post by ganjero »
is the DC Pump area in portal static or dynamic? Mine shows ReefCrest Speed 100%. Is it supposed to show what mode and the max speed are onlly? or update and show current pump speed?
Its based on the memory setting not the current speed or mode unless you are using memory
