Power Outage code Problems
PostPosted: Mon Jul 15, 2013 7:27 pm
first, here is my complete code if needed for review:
    #include <WiFiAlert.h>
     // Globals for Params on Custom Main
    byte x,y;
    // Define Custom Variables for Portal
    #define Var_Power        1
    // Custom Menu
    #include <avr/pgmspace.h>
    prog_char menu0_label[] PROGMEM = "Turn Lights On";
    prog_char menu1_label[] PROGMEM = "Turn Lights Off";
    prog_char menu2_label[] PROGMEM = "Start Feeding";
    prog_char menu3_label[] PROGMEM = "Start Water Change";
    prog_char menu4_label[] PROGMEM = "Clear Overheat";
    prog_char menu5_label[] PROGMEM = "Calibrate pH";
    prog_char menu6_label[] PROGMEM = "Calibrate Salinity";
    menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label  };
    void MenuEntry1()
    ReefAngel.DisplayMenuEntry("Item 1");ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
    #ifdef RelayExp
    for ( byte i = 0; i < MAX_RELAY_EXPANSION_MODULES; i++ )
        ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
    #endif  // RelayExp
    ReefAngel.Relay.Write();
    void MenuEntry2()
    ReefAngel.DisplayMenuEntry("Item 2");ReefAngel.Relay.RelayMaskOn = 0;
    #ifdef RelayExp
        ReefAngel.Relay.RelayMaskOnE[i] = 0;
    #endif  // RelayExp
    void MenuEntry3()
    ReefAngel.DisplayMenuEntry("Item 3");ReefAngel.FeedingModeStart();
    void MenuEntry4()
    ReefAngel.DisplayMenuEntry("Item 4");ReefAngel.WaterChangeModeStart();
    void MenuEntry5()
    ReefAngel.DisplayMenuEntry("Item 5");ReefAngel.OverheatClear();
    void MenuEntry6()
    ReefAngel.DisplayMenuEntry("Item 6");ReefAngel.SetupCalibratePH();
    void MenuEntry7()
    ReefAngel.DisplayMenuEntry("Item 7");ReefAngel.SetupCalibrateSalinity();
    // End Custom Menu Globals
    // Define Relay Ports by Name
    #define DT_LightsOne       1
    #define DT_LightsTwo       2
    #define Unused3            3
    #define Unused4            4
    #define DT_LWM             5
    #define GT_LWM             6
    #define Unused7            7
    #define Unused8            8
    #define Unused11           Box1_Port1
    #define Unused12           Box1_Port2
    #define GT_LightsOne       Box1_Port3
    #define GT_LightsTwo       Box1_Port4
    #define DT_RWM             Box1_Port5
    #define GT_RWM             Box1_Port6
    #define DT_Heat            Box1_Port7
    #define DT_Pump            Box1_Port8
    #define RV_Heat            Box2_Port1
    #define RV_Pump            Box2_Port2
    #define GT_Heat            Box2_Port3
    #define Unused24           Box2_Port4
    #define Unused25           Box2_Port5
    #define Unused26           Box2_Port6
    #define Skimmer            Box2_Port7
    #define GT_Pump            Box2_Port8
    void setup() {
        ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize the menu
        ReefAngel.FeedingModePorts = DT_LWM | GT_LWM | GT_Pump | DT_Pump | DT_RWM | GT_RWM | Skimmer; // Turn off when feeding mode is activated is activated
        ReefAngel.WaterChangePorts = DT_Heat| DT_LWM | DT_RWM | GT_LWM | GT_RWM | GT_Pump | DT_Pump; // Turn off when water change mode is activated
        ReefAngel.TempProbe = T2_PROBE;  // Set the 2nd plug to be DT Main temp
        ReefAngel.OverheatProbe = T2_PROBE;  // to monitor the overheat and temperatures
        ReefAngel.OverheatShutoffPorts = DT_LightsOne | DT_LightsTwo | DT_Heat | GT_LightsOne | GT_LightsTwo | GT_Heat | Skimmer;  // Items turned off when Overheat temperature exceeded
        InternalMemory.OverheatTemp_write( 829 ); // Set the DT Overheat temperature setting
        ReefAngel.LightsOnPorts = DT_LightsOne | DT_LightsTwo | GT_LightsOne | GT_LightsTwo; // Toggle Lights
   // Ports that default on
        ReefAngel.Relay.On(DT_Pump); // Turn on DT Pump
        ReefAngel.Relay.On(GT_Pump); // Turn on GT Pump
        ReefAngel.Relay.On(Skimmer); // Turn on Skimmer
        CheckPower();           // Monitor for power outages
        ReefAngel.StandardLights( DT_LightsOne,14,00,22,00 ); // DT Lights on at 2:00pm and off at 10:00pm
        ReefAngel.StandardLights( DT_LightsTwo,22,00,01,00 ); // DT-Moon Lights on at 10:00am and off at 1:00am
        ReefAngel.StandardLights( GT_LightsOne,14,00,21,45 );  //GT Lights Main 2:00pm - 9:45pm
        ReefAngel.StandardLights( GT_LightsTwo,15,00,22,30 ); //GT Lights Actinic 3:00pm - 10:30pm
        ReefAngel.WavemakerRandom( DT_LWM,60,100 );
        ReefAngel.Relay.Set( DT_RWM, !ReefAngel.Relay.Status( DT_LWM ) ); //Randomize DT powerheads
        ReefAngel.WavemakerRandom1( GT_LWM,60,100 );
        ReefAngel.Relay.Set( GT_RWM, !ReefAngel.Relay.Status( GT_LWM ) ); //Randomize GT powerheads
        StandardHeater1( DT_Heat,779,791 ); //DT-Heat
        StandardHeater2( GT_Heat,779,791 ); //GT-Heat
       // if the hour is 2p or 8p, minute is 55 and seconds is 0, start the feeding mode
          if ( ((hour() == 14) || (hour() == 20)) &&
          (minute() == 55) &&
          (second() == 0) )
          if (hour()>=1 && hour()<6)  // Turn on Reservoir Pump
          ReefAngel.Relay.On(RV_Pump);
          ReefAngel.Relay.Off(RV_Pump);
        // turn on RV_Heat when temp falls below 76.0 and turn off when temp gets above 80.0
        if (ReefAngel.Params.Temp[T3_PROBE] <= 780 && ReefAngel.Params.Temp[T3_PROBE] > 0) ReefAngel.Relay.On(RV_Heat);
        if (ReefAngel.Params.Temp[T3_PROBE] >= 791) ReefAngel.Relay.Off(RV_Heat);
        //turn off DT pump when switch is tripped and sound buzzer
        //ReefAngel.Relay.Set(DT_Pump,ReefAngel.IO.GetChannel(0));
         //ReefAngel.PWM.SetDaylight(100-(ReefAngel.IO.GetChannel(0)*100));
        //turn off GT pump when switch is tripped and sound buzzer
        // ReefAngel.Relay.Set(GT_Pump,ReefAngel.IO.GetChannel(1));
        // ReefAngel.PWM.SetDaylight(100-(ReefAngel.IO.GetChannel(1)*100));
        //tell the portal we have a overflow problem
        // ReefAngel.CustomVar[0]=ReefAngel.IO.GetChannel(0);
        // ReefAngel.CustomVar[1]=ReefAngel.IO.GetChannel(1);
       //  ReefAngel.CustomVar[7]=1;
        //set up dosing pump one to run twice a week for 4 minutes
         //ReefAngel.Relay.Set(Box1_Port2,((weekday()==1||weekday()==4) && hour()==14 && minute()<6));
         //ReefAngel.Relay.Set (Box1_Port3,(hour()%2==0)); //stir chemicals in water top off unit
         ReefAngel.Portal("rossbryant1956");
void CheckPower() {
  static boolean powerOutage=false;
  static WiFiAlert powerAlert;
  if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY))
  // && (!ReefAngel.Relay.IsRelayPresent(EXP2_RELAY))) // Expansion Relay NOT present
    powerOutage=true;
    ReefAngel.Relay.Off(DT_LightsOne);
    ReefAngel.Relay.Off(DT_LightsTwo);
    ReefAngel.Relay.Off(Port3);
    ReefAngel.Relay.Off(Port4);
    ReefAngel.Relay.Off(Port7);
    ReefAngel.Relay.Off(Port8);
    powerAlert.Send("Power+Outage!");
    //ReefAngel.CustomVar[Var_Power]=1;
   if (powerOutage && ReefAngel.Relay.IsRelayPresent(EXP1_RELAY)) // Expansion Relay NOT present
    powerOutage=false;
    LastStart=now();
    powerAlert.Send("Power+restored.",true);
    // ReefAngel.CustomVar[Var_Power]=1;
     void StandardHeater1(byte HeaterRelay, int LowTemp, int HighTemp)
        if (ReefAngel.Params.Temp[T2_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
        if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
        if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
   void StandardHeater2(byte HeaterRelay, int LowTemp, int HighTemp) //Heater for Grow Tank
        if (ReefAngel.Params.Temp[T1_PROBE] == 0) return;  // Don't turn the heater on if the temp is reading 0
        if (ReefAngel.Params.Temp[T1_PROBE] <= LowTemp && ReefAngel.Params.Temp[T1_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay);  // If sensor temperature <= LowTemp - turn on heater
        if (ReefAngel.Params.Temp[T1_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay);  // If sensor temperature >= HighTemp - turn off heater
      int x,y;
      char text[7];
      ReefAngel.LCD.DrawDate( 6, 122 );  //6 pixels left, 122 lines down
      // I/O Expansion
      byte bkcolor;
      x = 14;
      y = 11;
      for ( int a=0;a<6;a++ )
      ReefAngel.LCD.DrawText(0,255,18,26,"GT");  //18 left, 10 down
      ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 37, text, Num8x8);
      ReefAngel.LCD.DrawText(0,255,57,26,"DT"); //57 left, 10 down
      ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 50, 37, text, Num8x8);
      ReefAngel.LCD.DrawText(0,255,94,26,"Res"); //94 left, 10 down
      ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
      ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 90, 37, text, Num8x8);
      ReefAngel.LCD.DrawText(0,255,16,52,"DT pH"); //18 left, 39 down
      ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 15, 65, text, Num8x8);
      ReefAngel.LCD.DrawText( 0,255,57,52, "GT pH"); //57 left, 39 down
      ConvertNumToString(text, ReefAngel.Params.PHExp, 100);
      ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 55, 65, text, Num8x8);
      ReefAngel.LCD.DrawText(0,255,100,52,"Sal"); //100 left, 39 down
      ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 98, 65, text, Num8x8);
      ReefAngel.LCD.DrawOutletBox( 12, 80, TempRelay );
       // Relay Expansion
      // Relay Expansion
      TempRelay = ReefAngel.Relay.RelayDataE[1];
      TempRelay &= ReefAngel.Relay.RelayMaskOffE[1];
      TempRelay |= ReefAngel.Relay.RelayMaskOnE[1];
      ReefAngel.LCD.DrawOutletBox( 12, 107, TempRelay );
    // ReefAngel.LCD.DrawGraph( 5, 5 );
The part I having the most trouble with is the power outage section:
void CheckPower() {
    powerOutage=true;
    powerOutage=false;
    LastStart=now();
I have two expansion units and relay boxes, you'll notice one of those relays commented out in this section because I was unable to follow the instructions that Lee gave me. I was trying to get the code to fire if both units dropped off the power grid. I have the main relay and RA on a UPS and the wifi alert is working great because when I was messing with it my phone was going berserk! Thanks Lee
So, Thx in advance, hope you see something I don't.
PostPosted: Tue Jul 16, 2013 2:38 am
Were you getting a compiler error or was it just not working?
Return to My PDE/INO file
