Portal Question
Related to the Portal
clw143
Portal Question
Post by clw143 »
How do I get rid of the these modules I don't have?
Re: Portal Question
I don't think you can.
Re: Portal Question
Nope. You can't. I've asked for it a few times. I think it's a marketing tactic to make you want those modules ;)
Re: Portal Question
Yeah don't want to see any Module Not Founds on the screen, must purchase the module. :)
farkwar
Re: Portal Question
Post by farkwar »
lnevo wrote:Nope. You can't. I've asked for it a few times. I think it's a marketing tactic to make you want those modules ;)
So if those fields are not customizable how do you set up fields for salinity orp etc for a second tank system?
Say you have a frag tank and a display tank with double of everything, not zero of something.
How does that work?
Re: Portal Question
You need another RA. I dont think you could have two orp or two salinity probes. Only the ph has a second.
Re: Portal Question
No. It will only take Salinity probe. I asked a little while ago because I wanted to put a probe in à mixing station I was thinking of sitting up.
Re: Portal Question
