// Define Relay Ports by Name
#define KalkDoser 1
#define WCEmpty 2
#define Autotopoff 3
#define Refugium 4
#define KalkStirrer 5
#define WCFill 6
#define Heater 7
#define Return 8
#define RODIValve Box1_Port1
#define Skimmer Box1_Port2
#define Unused Box1_Port3
#define Unused Box1_Port4
#define Unused Box1_Port5
#define Unused Box1_Port6
#define Unused Box1_Port7
#define Unused Box1_Port8
byte wpMode;
int WCstatus;
InternalMemory.LCDID_write(0);
ReefAngel.AddDateTimeMenu();
ReefAngel.PHMin=546;//PH7.0
ReefAngel.PHMax=734;//PH10.0
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.Timer[1].SetInterval(180);
ReefAngel.Relay.On( Return ); // Return Pump
ReefAngel.Relay.On( Skimmer ); // Skimmer
CheckPower(); // Monitor for power outages
ReefAngel.PWM.SetChannel( 0, PWMSlope(9,30,21,30,17,100,60,0) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(9,30,21,30,17,100,60,0) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(9,30,21,30,17,100,60,0) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(9,30,21,30,17,100,60,0) );
ReefAngel.PWM.SetChannel( 4, PWMSlope(9,30,21,30,17,100,60,0) );
ReefAngel.PWM.SetChannel( 5, PWMSlope(9,30,21,30,17,100,60,0) );
ReefAngel.WaterLevelATO(Port3,120,43,45);
if (ReefAngel.LowATO.IsActive()) ReefAngel.Relay.On(RODIValve);
if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(RODIValve);
ReefAngel.DosingPumpRepeat( Port1,0,45,6 );
if (ReefAngel.Params.PH>=850) ReefAngel.Relay.Off(KalkDoser);
ReefAngel.StandardLights( Port4,20,0,8,0 );
ReefAngel.Relay.Set(Port5,now()%7200<900);
ReefAngel.StandardHeater( Port7,780,785 );
if (hour()>=6 && hour()<8)
ReefAngel.PWM.SetDaylight( TidalSwellMode(70,true) ); // Tidal Swell at 70% on sync mode
ReefAngel.PWM.SetActinic( TidalSwellMode(70,false) ); // Tidal Swell at 70% on anti-sync mode
wpMode=0;
else if (hour()>=8 && hour()<9)
ReefAngel.PWM.SetDaylight( ReefCrestMode(65,20,true) ); // ReefCrest at 65% +/- 20 on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(65,20,false) ); // ReefCrest at 65% +/- 20 on anti-sync mode
wpMode=1;
else if (hour()>=9 && hour()<13)
ReefAngel.PWM.SetDaylight( ElseMode(60,30,true )); // ElseMode on sync mode, 60 +/- 30%
ReefAngel.PWM.SetActinic( ElseMode(60,30,false )); // ElseMode on anti-sync mode, 60 +/- 30%
wpMode=3;
else if (hour()>=13 && hour()<16)
ReefAngel.PWM.SetActinic( NutrientTransportMode(75,90,2000,false) ); // Nutrient Transport on anti-sync mode
wpMode=2;
else if (hour()>=16 && hour()<20)
wpMode=3;
else if (hour()>=20 && hour()<21)
wpMode=1;
else if (hour()>=21 && hour()<23)
wpMode=0;
ReefAngel.PWM.SetDaylight( SineMode(40,55,30,true) ); // Sine at 40% 55% with for 30s on sync mode
ReefAngel.PWM.SetActinic( SineMode(40,55,30,false) ); // Sine at 40% 55% with for 30s on anti sync mode
wpMode=4;
if (WCstatus==-1)
ReefAngel.Timer[1].Start();
WCstatus=0;
ReefAngel.Relay.On(WCEmpty);
WCstatus=1;
if (ReefAngel.WaterLevel.GetLevel()<=15 && WCstatus>0 && WCstatus<10) WCstatus++;
if (ReefAngel.WaterLevel.GetLevel()<=15 && WCstatus==10)
WCstatus=11;
ReefAngel.Relay.Off(WCEmpty);
ReefAngel.Relay.On(WCFill);
if (ReefAngel.WaterLevel.GetLevel()<=81 && WCstatus>10 && WCstatus<20) WCstatus++;
if (ReefAngel.WaterLevel.GetLevel()>81 && WCstatus==20)
ReefAngel.Relay.Off(WCFill);
ButtonPress++;
WCstatus=-1;
ReefAngel.Portal("Drs1210");
ReefAngel.ShowInterface(); // Display everything on the LCD screen
void CheckPower() {
static boolean powerOutage=false;
// Power Outage - turn off everything
if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY)) // Expansion Relay NOT present
powerOutage=true;
ReefAngel.Relay.Off(Refugium);
ReefAngel.Relay.Off(KalkStirrer);
ReefAngel.Relay.Off(Heater);
ReefAngel.Relay.Off(Skimmer);
// Power Restored - Turn things back on
if (powerOutage && ReefAngel.Relay.IsRelayPresent(EXP1_RELAY))
LastStart=now();
powerOutage=false;
ReefAngel.Relay.On(Return);
ReefAngel.Relay.On(Skimmer);
byte x = 6;
byte y = 2;
byte t;
char text[7];
ReefAngel.LCD.DrawDate(6, 3);
ReefAngel.LCD.DrawText(COLOR_BLACK,255,56,83, "Res");
ReefAngel.LCD.DrawText(COLOR_GREEN,255, 45, 83, "H");
ReefAngel.LCD.DrawText(COLOR_GREEN,255, 45, 91, "I");
ReefAngel.LCD.DrawText(COLOR_RED,255, 77, 83, "L");
ReefAngel.LCD.DrawText(COLOR_RED,255, 77, 91, "O");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 75, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 98, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 78, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 86, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 95, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 78, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 86, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 95, "|");
ReefAngel.LCD.DrawText(0,255,10,30,"Tank");
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,100,30,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 91, 40, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,8,68,"WC");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_CHOCOLATE, 25, 68, 10);
ReefAngel.LCD.DrawText(0,255,66,68,"Room");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_MEDIUMORCHID, 94, 68, 10);
ReefAngel.LCD.DrawText(0,255,15,83,"WL");
ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(),1);
ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 10, 91, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,26,91," %");
// WP40 Mode
ReefAngel.LCD.DrawText(0,255,18,12,"Jebao WP40 Mode:");
ReefAngel.LCD.Clear(COLOR_WHITE, 1, 21, 132, 21);
if (wpMode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255, 23, 21,"Tidal Swell");
else if (wpMode == 1) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255, 25, 21,"Reef Crest");
else if (wpMode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255, 8, 21,"Nutrient Trnsp.");
else if (wpMode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255, 30, 21,"Else Mode");
else if (wpMode == 4) ReefAngel.LCD.DrawLargeText(COLOR_RED,255, 30, 21,"Sine Mode");
ReefAngel.LCD.DrawText(0,255,96,83,"WP40");
ConvertNumToString(text, ReefAngel.PWM.GetActinicValue(),1);
ReefAngel.LCD.DrawLargeText(COLOR_OLIVE, 255, 99, 91, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,115,91," %");
// Main Relay box
ReefAngel.LCD.DrawOutletBox(14, 106, TempRelay);
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 14, 118, TempRelay );
ReefAngel.LCD.FillCircle(57,94,3,COLOR_RED);
ReefAngel.LCD.FillCircle(57,94,3,COLOR_GREEN);
ReefAngel.LCD.FillCircle(70,94,3,COLOR_RED);
ReefAngel.LCD.FillCircle(70,94,3,COLOR_GREEN);
static unsigned long LastChange=millis(); // Set the inital time that the last change occurred
static int Delay = random( 500, 3000); // Set the initial delay
static int NewSpeed = MidPoint; // Set the initial speed
static int AntiSpeed = MidPoint; // Set the initial anti sync speed
if ((millis()-LastChange) > Delay) // Check if the delay has elapsed
Delay=random(500,5000); // If so, come up with a new delay
int ChangeUp = random(Offset); // Amount to go up or down
if (random(100)<50) // 50/50 chance of speed going up or going down
LastChange=millis(); // Reset the time of the last change
if (WaveSync)
return NewSpeed;
return AntiSpeed;
