My wifi module was working fine until recently when I started having problems pulling memory information from the Reef Angel Client Suite. I had been using custom firmware on my router, and had assigned a static IP address. To rule out any problems, I reinstalled factory firmware on router, used no static IPs, enabled uPNP and port fowarding for port 2000. I then used Tera Term to do factory reset and then tried using all three methods listed in the wifi manual to configure the wireless module. It still has the blinking blue light and all software reports an IP address of 0.0.0.0. I've read through many posts but don't see any detailing being unable to configure it.
Robert
Cannot Configure Wifi Module
rschneider77
Re: Cannot Configure Wifi Module
Can you try using WPA2-PSK with AES encryption???
The pass phrase is case sensitive.
rschneider77
Yes, I am using WPA2-PSK with AES encryption. And I have double checked both SSID and passphrase to make sure they are correct.
Try using the tera term macro:
http://forum.reefangel.com/viewtopic.php?p=25160#p25160
http://forum.reefangel.com/viewtopic.php?p=28621#p28621
rschneider77
The macro you referred me to worked. I think the commands I was missing was "set w j" and "set i h".
Thanks rimai,
Robert
Thanks rimai,
Robert
