1. Memory and PDE files are different. You should only need to upload the memory file once, unless you are modifying things within your memory file. PDE files need to be uploaded each time they are changed, in their entirety. I was initially confused thinking that PDE's add to the running code within the memory config file, not true. I would upload the memory config file, then the pde config file each time I was modifying something with in the PDE (which was not necessary). The PDE code runs your controller based on the coded things within the file. Basically if you upload features a, b, and c with your pde and decide you want to add another feature, d you need to append it to your existing pde making it a,b, c, and d. Simply do that then upload your PDE and you should be good to go. RAGen is a huge help when it comes to initial setup. So until you get comfortable modifying your pde, memory, or features files, I highly suggest using the RAGen application. It's the easiest way to get up and running without knowing anything about coding.
2. pH calibration. REMOVE THE USB CABLE FROM YOUR COMPUTER before calibrating. I couldn't figure out why my probe was consistently reporting inaccurate pH readings, then I stumbled upon this post: http://forum.reefangel.com/viewtopic.ph ... e+ph+probe where Rimai
mentions stray voltage can impact the reading. This is exactly what my issue was, so the minute I unplugged the USB cable from my laptop, the pH went from 7... to ~8.3.
3. Features.h file? When I first tried to enable some stuff (wifi) I had some problems. I did not realize the importance of the ReefAngel_Features.h file. If you hear people talking about this file it's located in your Arduino/libraries/ReefAngel_Features/ directory, called ReefAngel_Features.h It has a bunch of stuff that you need to enable (by removing the //) if you want to use what's in it, (like wifi, WDT, etc).
4. Watchdog Timer. The monitoring-your-pieced-together-forum-based-code-concoction so when you realize your banner isn't updating while at work because the controller crashed and the only thing on is your return pump and heater you don't arrive home to the most expensive sushi you've ever bought can be totally avoided. The watchdog timer is in your ReefAngel_Features.h file and totally saves the day. Since enabling it, which just involved removing the //, I have had no issues whatsoever.
5. Ports 5 and 6. At the moment, the instruction manual doesn't really mention this, but these ports apparently have been designed with some extra stuff to support the rapid/sporadic toggling of wavemakers (pumps). Since you may end up toggling your wavemakers several times a minute, I have mine alternating every 15-30 seconds, use these ports for such activities.
6. Random wavemaker function. This one took me several days going through various posts of which I eventually found a modifiable version of the code I was looking for based off someone's PWM question where they had posted their PDE. So, I'm here to share it with you as one of the coolest, easiest, things to get up and running with your new controller (not to mention my corals absolutely love it).
randomSeed(analogRead(0));
ReefAngel.Timer[1].SetInterval(random(15,35));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port5);
Keep in mind you cannot use the ReefAngel.Wavemaker1(Port5); & ReefAngel.Wavemaker2(Port6); functions because they will interfere with the random stuff. Just comment it out and use the above code if that's what you're going for.
I've been using this code with 2 Hydor Koralia Evolution 750's in my 70 gallon and it works awesome.
7. ATO stuff. This has been one of the most rewarding and time saving things I have been able to implement. There's several posts about the float switches and if you are common folk, like myself, I tend to get rather confused. The following post explains them well along with how to get things working with both the float switches upright (meaning the wires point up out of the water): http://forum.reefangel.com/viewtopic.ph ... 4&start=20 The code Rimai suggested on page 3 I have been using without any issues. Still loving the fact I don't have to dump several gallons of RO/DI in the tank every couple of days, what a pain...now it stays even and more importantly my salinity levels are much more stable. I bought a TOM Aquarium Aqua Lifter Pump (http://www.amazon.com/Aquarium-Lifter-3 ... tsupplies1) that works awesome- it's super quiet and I can't even tell when it's on (have to check my RAClient ATO trending/status).
8. Sometimes the compiler/upload errors out. Don't know why but about 15% of the time it may take 3-4 attempts at compiling or uploading code successfully. If your code is legit it just may take a few times to get it loaded in the controller, and with my experience hasn't been anything to worry about. I just avoid doing anything on my computer while compiling or uploading code.
9. Accessing your controller from the net. If you are sort of router savvy, the site http://dyn.com/dns/dyndns-free/ offers free port-forwarding services. To get this working I setup my wifi adapter port to 80 (default http) and have the dyndns address point to my cable modem's IP addy. Then, within my router I forwarded port 80 requests to my RA wifi adapter LAN IP. So now I can be anywhere with internet access and view/control the status of my tank.
That's about all I can think of for now...as I learn things I'll add to this post, and hopefully others do too. The ReefAngel is an amazing product and puts a lot of options at the users disposal at an unbeatable price. Just gotta get over the learning curve and you'll be maxing out your memory before you know it!
