PaulTurner911 Code
Paulturner911
Re: PaulTurner911 Code
Post by Paulturner911 »
lnevo wrote:
lnevo wrote:
Changed extension of feeding mode to 15 minutes so total duration is 30. Feel free to make the 900 back to 1800.
Fixed the timer issue you had as well...sorry bout that one.
Force night mode to Constant instead of whatever is default mode (NTM was today's mode.)
Ok, so we changed to 1800 to 900 but never changed the comment line?
Correct. Was trying to match up with what you were trying to do. I didn't change the comments.
Paulturner911
Thanks Bud!!!!
Paulturner911
Any chance you had time to revise the code and implement the boolean?
Sorry i haven't yet, it fell off my radar. Give me a bit still, been super busy and tomorrow I am picking up my new mandarin! Nice and fat and trained to eat frozen! So I'll be busy holding the fish bag on the train home :)
Paulturner911
Thanks! No rush by any means.
I guess Ive been lucky, my mandrin eats ANYTHING!!
TRAIN?!? Where do you live?
Long Island Rail Road to manhattan every day. Fun. Not.
Ok, so this should do...
0:00 Feeding Mode Start (all pumps off)
0:15 Smart_NTM
0:30 Feeding Mode End (return pump on)
1:15 Smart_NTM end / Resume previous mode
Good Luck, keep me posted.
static boolean feedingStarted;
static unsigned long feeding;
if (ReefAngel.DisplayedMenu==FEEDING_MODE && !feedingStarted) {
    feedingStarted=true;
    feeding = now();
} else {
  feedingStarted=false;
// Feeding Mode is 30 minutes
if (now()-feeding<=900) {
  // First 15 minutes after feeding mode. Pump is off
  ReefAngel.DCPump.Speed=0;
} else if (now()-feeding<=(900+3600)) {
  // NTM after 15 minutes for the next 60 minutes
  ReefAngel.DCPump.Mode=NutrientTransport;
  ReefAngel.DCPump.Speed=InternalMemory.DCPumpSpeed_read(); // Resume previous speed
Paulturner911
Im getting an error 'redeclaration of long unsinged in feeding.
Here is my complete code
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit | Port8Bit;
ReefAngel.DayLights( Port1 ); // Return Pump
ReefAngel.StandardFan( Port2 ); // Canopy Fans
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
//Port 6 NOT USED (Possibly Skimmer)
ReefAngel.DayLights( Port7 ); // MH 1
ReefAngel.DayLights( Port8 ); //MH 2
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 4, MoonPhase() );
ReefAngel.PWM.SetChannel( 5,(0) );
ReefAngel.PWM.SetChannel( 5, MoonPhase() );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 60sec @ 11pm-12pm (every 15min)
if (hour() >=23 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<60);
//Kalk Stir 12pm-1pm
if (hour() >=12 & hour() < 13)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Off(Port5);
///// Place your custom code below here
// Add random mode if we set to Mode to Custom in portal
static int rmode;
byte modes[] = { ReefCrest, TidalSwell, ShortPulse, NutrientTransport };
if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
changeMode=false;
if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
feeding = now();
    feeding = now();
} else {
  // Night mode (go to 30%)
  ReefAngel.DCPump.Mode=Constant;
  ReefAngel.DCPump.Speed=30;
} else if (InternalMemory.DCPumpMode_read()==11) {
  ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
} else {
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
You didn't delete this part...
feeding=now();
Paulturner911
Somethings not right with the current code. The day after feedmode was activated the WP is at zero. Im guessing after NTM it never resumes our random custom mode. Also could you refresh me on the memory location of feedmode timer? Where could I find a list of all memory locations?
It's in the file in libraries/Globals/Globals.
Look for the string VarsStart.
Paulturner911
Any chance you could revisit your logic on the feedmode? I've set the feedtime in the memloc to 900 and once that completes the return pump AND the wp turn. I'd like the wp to run NTM for a while before the returns kick on. Any help would be great.
Set the feed mode to however long you want them off. 900 is when ntm kicks on.
Paulturner911
Tx!
Paulturner911
This doesn't seem to be the case. I've currently set the feedmode to 1800.... At the 900 mark nothing happens, and 0 all pumps turn on and run NTM.
Did you change 900 in your code at all? The code I posted above sets the speed to 0 only for the first 900 seconds after feeding mode started..then its NTM until 4500 seconds.
Can you set the feeding mode time longer than 1800 and tell me what happens at the 1800 mark?
What is port1 port2 port7 and port8?
Paulturner911
I dont have an appropriate file reader to read globals/globals for memory locations.
Ive set the feedmode to 1860 and at 1800 nothing happens. Im assuming that at 960 the NTM should activate, it doesnt.
Port1- RETURN PUMP
2-FANS
7-MH
8-MH
these all turn off in feed mode
this is my code:
} else {
Im baffled here too...between you and sacohen i feel like im losing my mind...
Roberto binder anyone need a second set of eyes...speed and mode should be reset at 901 seconds..
Paulturner911
Anyone?
Sorry... what is exactly that you want?
Sent from my SPH-L710 using Tapatalk 4
I know what the problem is. I'll post something tomorrow. Can you post your full code again.
Try this:
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
static boolean startFeeding=false;
if (ReefAngel.DisplayedMenu==FEEDING_MODE && startFeeding) {
feeding = now();
startFeeding=false;
} else {
startFeeding = true;
    feeding = now();
} else {
} else if (now()-feeding<=900+3600)) {
} else {
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
[/quote]
This was the section I modified
feeding = now();
startFeeding=false;
} else {
Paulturner911
Thanks Lee, Ill let you know in the next few days. I really appreciate it.
Paulturner911
No bueno. Ive run the feedmode 3 times set at 1200 and the oven timer set at 15min. the NTM mode does not kick in at 901 (299 in countdown on LCD) Infact, the WP is not calling anymode untill I power cycle the unit, then it calls NTM. Any help would be great.
Here is my current code:
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
feeding = now();
startFeeding=false;
} else {
} else {
Grrr
Alright will look at it again soon...are u sure you poaded this code successfully...the full code not editing ur existing????
It looks also like you messed up the if block because i don't see the conditional to go into night mode...the ntm section goes right into night mode. Please also post your full code. Stop pasting blocks.
I believe the code worked but went into night mode instead. Post the full code ill fix it and we'll try again.
Try this:
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
feeding = now();
startFeeding=false;
} else {
  feeding = now();
} else {
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
} else {
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
Ok not sure where the missing line went between NTM and night mode it was gone for the past few pages. Please try the above code.
