Remote PWM
Related to the Portal
ufgators2k
Remote PWM
Post by ufgators2k »
Is there a way to remotely set the current PWM channel levels?
Re: Remote PWM
Are you talking about the current for Jebao Pumps like the WP-25 or 40?
The answer is yes. You would need to set you code for the pumps to use the internal memory and then you can adjust setting in the web portal under Internal Memory>DC Pump (Jebao/Tunze)
ufgators2k
Re: Remote PWM
Sorry I should have been more clear. I had spotty Internet where I was. I have four Rapid LED drivers controlled via PWM. I want to be able to turn down the level remotely. The currently run on the parabola setting.
Re: Remote PWM
I'm not 100% sure of that, but I think you can. I'm sure someone else with more knowledge on this will chime in.
Re: Remote PWM
Yes, you can do that.
If you choose the path of using internal memory when using the wizard, you can use the portal to change the % of each channel for both start and end whenever you want to :)
ufgators2k
Re: Remote PWM
Is there any functional difference between using the memory vs calling the function in code?
