Relay Expansion Box has no power
djtutt
Post by djtutt »
I connected my 1st relay expansion box by the manual. All codes were accepted and the 2nd set of 8 channels show up on the Reef Angle screen but no power is coming from the box itself. I set it for all 8 to be "always on" and all lights are green but still no power when I plug something into the box. What am I doing wrong? Thanks in advance for help.
Re: Relay Expansion Box has no power
Please check the dip switches.
How old is your RA head unit?
djtutt
Post by djtutt »
Dip switches all off and Reef Angel unit was purchased March 12, 2012. Just received expansion on Friday.
Do you have 3 jumpers installed in the head unit?
You should, but just to confirm.
Also, check this thread and post the log of the I2CScanner code.
djtutt
Post by djtutt »
Ok, I'll change my dip switches on the expansion end and see what happens.
rossbryant1956
Post by rossbryant1956 »
just went thru this. Check this post, particularly my last "figured it out" post
http://forum.reefangel.com/viewtopic.ph ... 9&start=10
djtutt
Post by djtutt »
I tried different dip switch settings and the additional relay box still has no power.
rossbryant1956
go back into my post above, find the download for ic scan, upload it and past results
viewtopic.php?p=18831#p18831
djtutt
Post by djtutt »
I have swapped cables and boxes and they work but when I hook up the relay expansion, the green light is on but sockets on the box have no power. Here are my readings from the I2CScanner
I2CScanner ready!
starting scanning of I2C bus from 1 to 128...
addr: 1 addr: 2 addr: 3 addr: 4
addr: 5 addr: 6 addr: 7 addr: 8
addr: 9 addr: A addr: B addr: C
addr: D addr: E addr: F addr: 10
addr: 11 addr: 12 addr: 13 addr: 14
addr: 15 addr: 16 addr: 17 addr: 18
addr: 19 addr: 1A addr: 1B addr: 1C
addr: 1D addr: 1E addr: 1F addr: 20 found!
addr: 21 addr: 22 addr: 23 addr: 24
addr: 25 addr: 26 addr: 27 addr: 28
addr: 29 addr: 2A addr: 2B addr: 2C
addr: 2D addr: 2E addr: 2F addr: 30
addr: 31 addr: 32 addr: 33 addr: 34
addr: 35 addr: 36 addr: 37 addr: 38
addr: 39 addr: 3A addr: 3B addr: 3C
addr: 3D addr: 3E addr: 3F addr: 40
addr: 41 addr: 42 addr: 43 addr: 44
addr: 45 addr: 46 addr: 47 addr: 48
addr: 49 addr: 4A addr: 4B addr: 4C
addr: 4D addr: 4E addr: 4F addr: 50 found!
addr: 51 addr: 52 addr: 53 addr: 54 found!
addr: 55 addr: 56 addr: 57 addr: 58
addr: 59 addr: 5A addr: 5B addr: 5C
addr: 5D addr: 5E addr: 5F addr: 60
addr: 61 addr: 62 addr: 63 addr: 64
addr: 65 addr: 66 addr: 67 addr: 68 found!
addr: 69 addr: 6A addr: 6B addr: 6C
addr: 6D addr: 6E addr: 6F addr: 70
addr: 71 addr: 72 addr: 73 addr: 74
addr: 75 addr: 76 addr: 77 addr: 78
addr: 79 addr: 7A addr: 7B addr: 7C
addr: 7D addr: 7E addr: 7F addr: 80
done
djtutt
Post by djtutt »
Checked main unit and there was only one jumper. (All three jumpers must be installed in head unit in order for any expansions to be recognized)
rossbryant1956
do you have spare jumpers? Should be attached to the pins inside the head unit, just not installed on both pins. If no, radio shack has them for pennies.
djtutt
Post by djtutt »
Picked up some jumpers from my job and my relay expansion box is up and running. Thanks for the help.
rossbryant1956
It was my pleasure. I have received so much help on this board when there is a time when I can give back I really try to. Thx to all for your support from all of us.
