I have unplugged everything and waited a minute or two and plugged it all back in. I verified the switches are working correctly by moving them by hand and verifying the Reef Angel Client shows ATO high or low as green. I have reuploaded the code twice now and still, everytime I plug the pump in it just starts pumping.
Below is my code. Any help would be greatly appreciated!
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port2Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit;
ReefAngel.DCPump.FeedingSpeed=30;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.DelayedOn( Port1,1 );
ReefAngel.StandardLights( Port2,23,0,11,0 );
ReefAngel.StandardHeater( Port4,780,800 );
ReefAngel.Relay.DelayedOn( Port6,1 );
ReefAngel.StandardATO(Port8,1200);
if (hour()>=0000 && hour()<8)
ReefAngel.DCPump.SetMode( Constant,30,10 );
if (hour()>=8 && hour()<9)
ReefAngel.DCPump.SetMode( Lagoon,40,10 );
if (hour()>=9 && hour()<20)
ReefAngel.DCPump.SetMode( ReefCrest,55,20 );
if (hour()>=20 && hour()<21)
if (hour()>=21 && hour()<2359)
