Serious ATO issues
meadowsad
Serious ATO issues
Post by meadowsad »
After a water change today my ATO decided to kick on and luckily only dumped 2-3 gallons of water in my sump. The water change was from the display tank so it shouldn't have triggered the low switch to start the pump. Prior to this the ATO has been working fine for about a week. Now the ATO will not shut off. I am using 2 float switches one pointing down, one pointing up.
I have unplugged everything and waited a minute or two and plugged it all back in. I verified the switches are working correctly by moving them by hand and verifying the Reef Angel Client shows ATO high or low as green. I have reuploaded the code twice now and still, everytime I plug the pump in it just starts pumping.
Below is my code. Any help would be greatly appreciated!
    ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.LightsOnPorts = Port2Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit;
    ReefAngel.DCPump.FeedingSpeed=30;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.DelayedOn( Port1,1 );
    ReefAngel.StandardLights( Port2,23,0,11,0 );
    ReefAngel.StandardHeater( Port4,780,800 );
    ReefAngel.Relay.DelayedOn( Port6,1 );
    ReefAngel.StandardATO(Port8,1200);
    if (hour()>=0000 && hour()<8)
    ReefAngel.DCPump.SetMode( Constant,30,10 );
    if (hour()>=8 && hour()<9)
    ReefAngel.DCPump.SetMode( Lagoon,40,10 );
    if (hour()>=9 && hour()<20)
    ReefAngel.DCPump.SetMode( ReefCrest,55,20 );
    if (hour()>=20 && hour()<21)
    if (hour()>=21 && hour()<2359)
Re: Serious ATO issues
Well at initial observation, you have a 20 minute timeout on your pump. That seems a but excessive.
Also even if you are removing water from DT it will affect the water level in your return chamber as there is less water to overflow down your drain.
It could be a stuck relay. Do you have wifi? If you override the port to off does it still pump?
meadowsad
Post by meadowsad »
I shut all the pumps off during a water change so yes the water level in the sump raises but that should trigger the ATO high switch, not the ATO low. Not sure what you mean here.
The 20 minute timeout was based on trial and error it could probably be lowered a bit but it was working fine for a week. With the pump I have at most it would pump in is a little over 1 gallon.
I have tried turning the ports on then off and even when they say off the pump still runs.
Sounds like a stuck relay. Try the controller test sketch and see if you can turn it off with that.
Alternatively you could put
ReefAngel.Relay.Off(Port8);
After the standard ato call. And see if it stays off.
meadowsad
Post by meadowsad »
Thanks for the help. I'll give that a go and see what happens. My concern is if this happens again while I am away. Is this a somewhat common problem? Is there anyway this can be avoided?
meadowsad
Post by meadowsad »
New development. I was watching TV and I heard a "grinding" sound coming from the fish tank. I checked the tank and the sound was coming from the relay box. The relay was turning on and off very rapidly. Not sure how I should proceed now but I assume something is not right.
Your code seems to be missing something.
Where is ReefAngel.ShowInterface()?
meadowsad
Post by meadowsad »
I have just added that in to my code based off of where it is in the preloaded code. This did not resolve the issue. One thing I did notice is the pump doesn't turn on until the delayed ports turn on.
Below is my new code:
    ReefAngel.Portal( "meadowsad" );
meadowsad
Post by meadowsad »
I uploaded the controller test code and went through all the ports.
What I noticed was when I turn on port 6(skimmer), port 8(ATO pump) also turns on. I didn't even make it all the way to port 8 before the pump started pumping. I went to port 7 and port 6 and 8 were still on even though they showed off. Going to port 8 and then back to 7 didn't do anything either. Only when I went back to port 5 then ports 6 and 8 turn off.
Are you using the original svga cable?
meadowsad
Post by meadowsad »
Everything is stock. The only add-on I have is the WiFi attachment.
You will need to send for repair then.
PM for RMA.
