void ReefAngelClass::DayLights(byte Relay)
StandardLights(Relay);
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, COLOR_WHITE, 6, 4, " Martin's BC29");
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 17, 132, 17);
x = 12;
y += MENU_START_ROW+1;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, " Display PH");
char text[7];
ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text);
y += MENU_START_ROW*2;
x = 10;
ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+(16*4),y+16);
ReefAngel.LCD.DrawHugeNumbers(T1TempColor, DefaultBGColor, x, y, text);
x += (16*4) + 8;
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,8,y+25,"Hood:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], T2TempColor,
9, y+35, 10);
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+8,y+25,"Room:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], T3TempColor,
x+9, y+35, 10);
//ReefAngel.LCD.DrawText(0,255,20,80,MoonPhaseLabel());
//ReefAngel.Use2014Screen(); // Let's use 2014 Screen
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
ReefAngel.DosingPumpRepeat1( Port4 );
ReefAngel.DosingPumpRepeat2( Port5 );
ReefAngel.StandardATO( Port6 );
//ReefAngel.PWM.SetDaylight( MoonPhase() );
//ReefAngel.PWM.SetActinic( MoonPhase() );
ReefAngel.Portal( "89delta" );
ActinicPWMValue=PWMSlope(10,00,22,15,0,50,40,ActinicPWMValue);
DaylightPWMValue=PWMSlope(10,00,22,15,0,50,40,DaylightPWMValue);
CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 50
#define Min_Cloud_Duration 5
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 10
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if (lightningchance)
int x=0;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
}Code: Select all
#include <SunLocation.h>
SunLocation sl;
byte x = 6;
byte y = 2;
byte t;
x = 12;
char text[7];
x = 10;
x += (16*4) + 8;
9, y+35, 10);
x+9, y+35, 10);
sl.Init(-18.285833, 147.699722); // In decimal numbers (i.e. -18.285833, 147.699722)
// handle updating sunrise and sunset values
sl.CheckAndUpdate();
sl.SetOffset(0,0,0,0); // rise_hour, rise_seconds, set_hour, set_seconds
ActinicPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),0,50,40,ActinicPWMValue);
DaylightPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),0,50,40,DaylightPWMValue);
CheckCloud();
void CheckCloud()
#define Min_Cloud_Duration 6
#else
#endif
if (cloudchance)
if (cloudchance)
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
int x=0;
int x=0;
cstart*=60;
cend*=60;
