Currently I have basically 2 containers - 1 with salt water and the other with RO water.
I currently use the waterlevel ato function to top up salt water and a salinity measure to top up RO.
These work independently of each other which is for the most part fine, but what happens occasionally is, my skimmer section of my sump might overfill a bit if for example the water level expansion (salt water) has just topped up to "40" and then the salinity is low and so RO water is added.
I have posted my code below for this.
What I would like to do, is change the following -feel free to come up with other suggestions as I may be looking at this wrong!!
1. Only enable waterlevelATO (saltwater) function if my salinity is <33.1ppt
2. Only enable RO top up if water level <40.
I think what i need to do is add the below:
if (SalCompensation<33.1)
ReefAngel.WaterLevelATO(Port2,180,35,40);
and
if Reefangel.WaterLevel.Getlevel () <= 40
ATOEnabled=true;
ATOPumping=false;
Is this correct???
Your help as always is appreciated!!
unsigned long lastLowSal=now();//salinity >35.1 timer
boolean SALduration=true;//salinity >33.1 for 2 minutes flag
boolean ATOEnabled=false;//enable ATO function for 5 seconds
boolean ATOPumping=true;//disable ATO function for 5 minutes
unsigned long ATOStart=now();//ATO 5 sec run timer
double Salinitytest;
InternalMemory.OverheatTemp_write( 260 );
InternalMemory.SalTempComp_write( 255); // Change this to compensation temperature
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Timer[1].SetInterval(1800); // 30 mins before reactivation of ATO
//ReefAngel.Relay.DelayedOn( Port3,5 );//skimmer delay on switching on
ReefAngel.StandardHeater( Port6,252,255 );
ReefAngel.StandardFan( Port7,255,258 );
ReefAngel.WaterLevelATO(Port2,180,35,40);// Salinty top up to keep water level correct
// Apply Salinity temp Compensation & salinity calibration
double SalCompensation;
if (ReefAngel.TempSensor.unit)
SalCompensation=ReefAngel.Params.Salinity/(1+((ReefAngel.Params.Temp[T3_PROBE]-InternalMemory.SalTempComp_read())*0.0022));
SalCompensation=ReefAngel.Params.Salinity/(1+((ReefAngel.Params.Temp[T3_PROBE]-InternalMemory.SalTempComp_read())*0.001165));
SalCompensation=round(SalCompensation);
// For displaying salinity without temp compensation
Salinitytest=SalCompensation;
///// If salinity >33.1 for 120 sec set SALduration flag
if (SalCompensation<331) lastLowSal=now();
if (now()-lastLowSal>120) SALduration=false;
if (SALduration && ATOPumping)//if salinity>33.1 for 2 minutes enable ATO
{ATOStart=now();
ATOEnabled=true;
ATOPumping=false;
if (now()-ATOStart<5)//ATO pump on time 5 seconds
if (ATOEnabled) ReefAngel.Relay.On(Port1);
ReefAngel.Timer[1].Start();//start 5 minute disable of ATO
ReefAngel.Relay.Off(Port1);
ATOEnabled=false;
if (ReefAngel.Timer[1].IsTriggered())//after 30 minute disable, enable ATO
ATOPumping=true;
ATOStart=now();
SALduration=true;
///// if skimmer cup full, turn off skimmer
bitClear(ReefAngel.Relay.RelayMaskOff,2);
else {
bitSet(ReefAngel.Relay.RelayMaskOff,2);
ReefAngel.Portal( "dazza1304" );
int x,y;
// Parameters
// Salinity
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,15,46, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,39,46, ReefAngel.Params.Salinity );
//map of adc temp comp salinity
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,15,63, "SAT:" );
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,39,63, (int)Salinitytest );
// ORP
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,75,46, "ORP:" );
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,99,46, ReefAngel.Params.ORP );
// Water Level
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,75,63, "WL:" );
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,99,63, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 79, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 98, TempRelay );
// Date and Time
