While I was doing maintenance a few drops of water got into a plug on my RA and a small fire ensued on two cords. I unlpugged everything and then restarted the tank without the RA on the system.
1. Is the box safe to use
2. If not can I replace it
3. Is there anything else I should know about this situation?
Please advise, RA ON FIRE
Re: Please advise, RA ON FIRE
Was it on the relay box?
If it is, I'd not recommend you using it.
You got PM
You got PM
