Ph probe gone bad?
Re: Ph probe gone bad?
Bulk Reef Supply. They have a value probe for like $25, I paid like $40 for the pin point. They have a good priced lab grade probe which supposedly last longer, but at the time I wasn't sure if it was probe or voltage... so I went with the pin point, seemed a good compromise.
Piper
Post by Piper »
+1 on the BRS probe. I've been using their cheap probe for almost 2 years and its still doing fine.
~Charlie
daniella3d
Post by daniella3d »
I checked for stray voltage and there does not seem to be any as the probe keep dropping even in a cup of water, does not matter. I replaced the probe for a cheap ebay probe. Seem to be working well so far.
chapboogie
Post by chapboogie »
I have been having ph probe issues since I got my RA. I tried calibrating. Seemed to only get worse. I waited a few months and got new solution, and just tried to calibrate. Still the same problem.
I'm getting swims from 1.8 to 7.9 in a day period. Everything in the tank looks fine.
Can it just be a bad probe.
Sent from my SCH-I535 using Tapatalk 4
chapboogie
I've found my probe reasons go extremely low while my lights are on while it is dimming up.
chapboogie
chapboogie wrote:I've found my probe readings go extremely low while my lights are on while it is dimming up.
Did you try disconnecting your drivers to see what happens?
chapboogie
I shutoff that relay and watched it slowly raise back up. When my dimming cycle gets to about 75 percent of peak the ph returns to normal readings.
chapboogie
Do you think it could be due to analog dimmers? I see no place where wiring is touching either the tank or other wiring
Sounds like your drivers are doing that.
If you disconnect the dimming wires from the side of relay box, does it raise back up too?
chapboogie
rimai wrote:Sounds like your drivers are doing that.
No, but the lights aren't on with them unplugged either.
Why would the driver cause the oh probe to read wrong? There is nothing with the writing from the lights touching anything on the tank or the probe wire
It doesn't matter whether the lights are on or not.
They are still connected and share the same ground.
The standard dimming ports are non-isolated. The newer expansion dimming ports are isolated.
So, if your drivers are leaking anything. You will need to either replace the drivers with ones that don't do that or isolate them with the dimming module.
chapboogie
Why does it quit when the dimmers get past a certain amount?
Not sure... What drivers are you using?
Maybe at lower dimming the resistance is causing some kind of feedback? Makes sense in my head :)
chapboogie
Meanwell ELN-60-48D.
chapboogie
It would be weird for both drivers to send back a leak, wouldn't it?
Are you dimming them seperately? or together?
chapboogie
Separately
chapboogie
One analog channel for blue, one for white
Do you turn off the relay the drivers are on or let them shut off dimming to 0? If the power is on the same relay box for the drivers can you try them in a different outlet perhaps non ra controlled?
Is it definitely either channel adding the interference? Or could it be just one causing it?
chapboogie
I let them dim to 9 percent which is off. Then the relay follows
chapboogie
If they dim to 0, are the lights using any electricity?
chapboogie
Tried moving to a outlet off the wall, no difference. Even tried a different wall.
chapboogie
Finally got a multimeter to measure stray voltage. I measure 2.6 with ph probe out of the water, lights on. Plug in ph and get close to 9 volts. I also keep getting my screen to blank out even though I replaced to screen. Do I have a voltage issue with my RA?
chapboogie
My screen only works after I unplug and restart RA. Then after it sleeps turns on just white
chapboogie
I replaced the screen about 3 months ago. Worked fine for a while, then back to doing it. I wonder if I have a bad unit
Can you still access the controller with apps when the screen is black?
