jebao and feeding mode
im getting ready to order my jebao cable for my wp-40. my one question is do you still have to shut down the power to the pump to shut it off during feeding mode or can these be turned down to 10% during feeding mode with just the pwm dimming signal?
Re: jebao and feeding mode
You can write the code so that it goes to 10% or 0% or even 20% (like I have it) during feeding mode.
Depending on how you are setting up the Jebao there are a couple of ways to code it.
I have mine like this, but it may be different depending on your code.
This will take it to 20% during Feeding and off during a water change.
lnevo is working up some new code for my De-nitrification unit and he said he was going to correct the way this is to so it can be adjusted from the portal.
if( ReefAngel.DisplayedMenu==FEEDING_MODE ) ReefAngel.PWM.SetActinic(20);
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE ) ReefAngel.PWM.SetActinic(0);
Just an fyi. I'm off next week so should have some time to take a stab at it...
If that was directed to me and the De-nitrification coding, no problem. I know you are busy and you are doing me a huge favor so I understand.lnevo wrote:Just an fyi. I'm off next week so should have some time to take a stab at it...
Thanks again
Yes. For the OP, I recommend using the new DCPump configuration and you can set the Feeding mode speed and it should work without any custom coding.Sacohen wrote:If that was directed to me and the De-nitrification coding, no problem. I know you are busy and you are doing me a huge favor so I understand.lnevo wrote:Just an fyi. I'm off next week so should have some time to take a stab at it...
Thanks again
thanks for the reply's guys. That's what i figured but i just want to ask. i will bring this subject back up when i get the cable. thanks you the reassurance.
