Relay Expansion Module
clw143
Post by clw143 »
Does adding a relay expansion module and relay box give you 2 additional PWM ports?
Re: Relay Expansion Module
Nope, but if they are different you can swap with your main relay box.
clw143
Post by clw143 »
That seem like an opportunity for you all to expand on :mrgreen:
Not sure what you mean, but technically its not possible as the expansion bus is only 4 wires and no way to talk to the pwm ports and control the relays on that bus.
clw143 wrote:That seem like an opportunity for you all to expand on :mrgreen:
It's been brought up before, but as lnevo said it a hardware limitation although it would be nice to have use of the additional PWM ports. the system is always changing and updating so who knows what the future entails.
