Added second Tunze, now pumps turn on/off rapidly
meadowsad
Post by meadowsad »
So I just got my Reef Angel back from repair, I took this opportunity to add a second pump while I was hooking everything up. I have now 2 Tunze 6095s controlled by the Reef Angel. I am using the same exact code but the pumps are not behaving as expected. When I had one pump it would gradually speed up and slow down. Right now both pumps are turning on and off rapidly. Am I missing something in my code now that I have a second pump? Also when I go to Feeding Mode the pumps stop completely. I am so lost right now, help!
    ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port5Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.DCPump.FeedingSpeed=30;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.DelayedOn( Port1,1 );
    ReefAngel.Relay.DelayedOn( Port2,1 );
    ReefAngel.StandardHeater( Port7,780,800 );
    ReefAngel.StandardATO(Port8,1200);
    if (hour()>=0000 && hour()<8)
    ReefAngel.DCPump.SetMode( Constant,30,30 );
    if (hour()>=8 && hour()<9)
    ReefAngel.DCPump.SetMode( Lagoon,30,30 );
    if (hour()>=9 && hour()<20)
    ReefAngel.DCPump.SetMode( ReefCrest,70,70 );
    if (hour()>=20 && hour()<21)
    if (hour()>=21 && hour()<2359)
    ReefAngel.Portal( "meadowsad" );
Re: Added second Tunze, now pumps turn on/off rapidly
Code looks fine.
Did you have the same exact code before?
meadowsad
Post by meadowsad »
Yes, same exact code. I had to upload the code again since it looked like you had some test code in there after the repair. I even ran the wizard again and tried the dc pumps in reef crest mode without all the code for the times and it does the same thing.
Another thing I tried was just setting the ports to be always on. The control cable had to be unplugged for this to work. This code has the pumps on all the time, not being controlled, as expected.
    ReefAngel.Relay.On( Port2 );
    //ReefAngel.Relay.DelayedOn( Port1,1 );
    //ReefAngel.Relay.DelayedOn( Port2,1 );
    //ReefAngel.DCPump.UseMemory = false;
    //ReefAngel.DCPump.SetMode( ReefCrest,70,70 );
    //ReefAngel.DCPump.DaylightChannel = Sync;
    //ReefAngel.DCPump.ActinicChannel = AntiSync;
mudcat1
Post by mudcat1 »
Meadowsad,
Does the pump start and stop only when the pump speed is set to 30? Try to increase the minimum speed to 40 to see if the pumps no longer stop and start.
meadowsad
Post by meadowsad »
I tried with the pumps set at 70 and no luck. I did notice some more weirdness though. After a short amount of time on of the pumps started spinning fine. Then I left to go to the store and when I came back both pumps were off when it should have switched from reef crest to lagoon mode.
meadowsad
Post by meadowsad »
Is there any code I should try to see if the pumps run normally?
Try removing all the if statements and set the channels to 70% to see what it does
Sent from my SPH-L710 using Tapatalk 4
meadowsad
Post by meadowsad »
I removed all the extra code and just had this line
ReefAngel.DCPump.SetMode( ReefCrest,70,20 );
The pumps still turned on and off rapidly.
No, try setting them to always 70%
ReefAngel.PWM.SetActinic(70);
ReefAngel.PWM.SetDaylight(70);
meadowsad
Post by meadowsad »
I used the code below like you suggested and the pumps were spinning while the code was uploading but as soon as it was done the pumps started turning on and off rapidly.
You mentioned you had a repair done. May I ask what it was??
It sounds like you have the wrong dimming signal.
meadowsad
Post by meadowsad »
So now that you mention that...
I had an issue with port 6 turning on and off rapidly on the relay box. In the PM you sent back to me you said there was a defective chip in the head unit and you replaced the chip.
Also I ordered a relay expansion module with box while I waited for my unit to be repaired. Would using the new relay box instead of the original have anything to do with that? I can't be sure which one I am using because I got them mixed up.
Yes.
You must use the original one.
The original one will have a sticker "Analog Dimming" at the bottom
meadowsad
Post by meadowsad »
Sorry for being an idiot.... lol
There is no such thing... :)
