I'll try to keep this short... I'm Rob.. I currently have a small 45gal reef tank with a 20gal sump in my living room. I'm running the Nova Extreme Pro 36inch T5 light that has seperate White and Actinic controls.
In the next few months, we will be renovating this space of our home. The Tank will be moved to my basement office where it will most likely stay. I will utilize the opportunity of the renovation to add a larger display tank to the living room. It will be a 4 foot tank (75/90 or 120). I'll most likely plumb all the tanks together with the sump in the basement.
For the future tank I will take my time buying all the components and when I have them all I will do the build.
Ok.. so on to the Reef Angel.. I'm a computer guy.. Actually a Cisco Network Engineer.. so I don't think I'll have any issues grasping the technology.
I think I know the answers to these questions But I'd like to be sure:
1 - Can I use the RA to control my current lights? I assume it's just programming the two light ports on the Relay and plug the lights into them?
2 - Ultimately, Can I use the RA to control both tanks (T5's on 45, LEDs on Livingromm tank, ATO in sump, etc)?
3 - If the RA is in the basement, how can I control the LED's upstairs? I know I need to extend cables.. but which side of the LED driver gets extended? In other words, are the drivers located in in the basement near the RA, or up in the display tank area?
I think I'm going to buy the RA in the next week or so .. work Bonus is due on Aug31st
thanks for your time!
