Pretty proud of myself..
RA+ installed.. running how I want it...
I did use the wizard though..
I also need to understand how the ATO works.. Previously I used a homemade ATO using a Relay and two floats. So if I lifted the lower float, the water flow would stop instantly. It seems the RA ATO works a bit differently.
I'm using the Aqualifter pump that really does not move much water. I quickly realized that a 60 second timeout would not work. I just upped it to 15 minutes.. If I manually raise the floats, the pump does not turn off. What triggers the pump to turn off, the float switch, or the timeout value?
Rob
