PaulTurner911 Code
Re: PaulTurner911 Code
lnevo wrote:Im baffled here too...between you and sacohen i feel like im losing my mind....
I've been following this thread, because I want to set this up eventually and I saw this..
Sorry man. :(
No worries... I believe I found the errors... hopefully it should work. :) You just want the random piece, no?
Yes the randomness of the water modes and the Nutrient Transport Mode after feeding, but like you said wait until we have the other stuff working first.
I've just been following along for now.
Paulturner911
Post by Paulturner911 »
Thanks Lee, Ive been tied up and hadnt tried the revised code. The previous COMPLETE code you had posted gave me an error, so I cut in the "modified section" Thats how I ended up with the last (my current) code. Ill use your new code in its entirety and run it this afternoon.
Thank you again for all of your help and patience with us "noncoders" :)
Let me know if there's a compile error. I'd rather review it then have you potentially load bad code.
Paulturner911
Compile error:
static unsigned long feeding;
redeclaration of 'long unsigned int feeding'
Try this:
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit | Port8Bit;
ReefAngel.DayLights( Port1 ); // Return Pump
ReefAngel.StandardFan( Port2 ); // Canopy Fans
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
//Port 6 NOT USED (Possibly Skimmer)
ReefAngel.DayLights( Port7 ); // MH 1
ReefAngel.DayLights( Port8 ); //MH 2
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 4, MoonPhase() );
ReefAngel.PWM.SetChannel( 5,(0) );
ReefAngel.PWM.SetChannel( 5, MoonPhase() );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 60sec @ 11pm-12pm (every 15min)
if (hour() >=23 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<60);
//Kalk Stir 12pm-1pm
if (hour() >=12 & hour() < 13)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Off(Port5);
///// Place your custom code below here
// Add random mode if we set to Mode to Custom in portal
static int rmode;
byte modes[] = { ReefCrest, TidalSwell, ShortPulse, NutrientTransport };
if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
changeMode=false;
static boolean feedingStarted;
if (ReefAngel.DisplayedMenu==FEEDING_MODE && !feedingStarted) {
  feedingStarted=true;
  feeding = now();
} else {
  feedingStarted=false;
// Feeding Mode is 30 minutes
if (now()-feeding<=900) {
  // First 15 minutes after feeding mode. Pump is off
  ReefAngel.DCPump.Speed=0;
} else if (now()-feeding<=900+3600)) {
  // NTM after 15 minutes for the next 60 minutes
  ReefAngel.DCPump.Mode=NutrientTransport;
  ReefAngel.DCPump.Speed=InternalMemory.DCPumpSpeed_read(); // Resume previous speed
  // Night mode (go to 30%)
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
  ReefAngel.DCPump.Mode=Constant;
  ReefAngel.DCPump.Speed=30;
} else if (InternalMemory.DCPumpMode_read()==11) {
  ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
} else {
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
That was one of the result of constant merging :)
Paulturner911
Compile error:
expected primary-expression before ')' token
} else if (now()-feeding<=(900+3600)) {
Paulturner911
This is my current code, it is not calling NTM at 901 (299 countdown) not modes are acitvated until I power cycle the RA.
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
  feeding = now();
} else {
} else {
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
It is night mode now...lets try during the day. At least lets see if any difference. We're going to need to do some serial prints and see what is happening better...
Sorry this is messing you up here. I'm going to double check and triple check it all tomorrow. Maybe I will take a different approach and update memory and maybe use some custom vars to get some feedback on where we are...
Paulturner911
Thanks Lee. We had everything correct until we stepped over to the DC Pump Control :X .... I dont think it calls night mode until 10:30 so I think I was clear of that when I ran feedmode. Keep me posted, its not the biggest deal in the world, but Id like to get it up and running.
Me too!!
Ok, I found something obvious that would keep it in Step 1 of our routine...try this:
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
if (ReefAngel.DisplayedMenu!=FEEDING_MODE) feedingStarted=false;
  feeding = now();
} else {
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
Paulturner911
No go. It did call NTM at some point after the feedmode timed out, but only the first time I ran it.....The second time it activated another mode. This is not happening immediately after feedmode times out, but within 20min after.
Ok that sounds like some progress...let me work on it.
Ok. I think I got it!!! The issue is we extended feeding mode to the 30. Minutes but tried to change the mode to smart NTM and the speed, but when feeding mode is running the FeedingSpeed setting was overwriting what we were doing.
What we need to do is reduce the feeding timer to 15 minutes and then when we initiate the first 15 minutes after feeding mode we keep the return pump off for the extra 15 minutes while setting smart NTM. Then we can have smart NTM continue for the hour after that.
Please try this:
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
if (now()-feeding<900) {
  // First 15 minutes after feeding mode stops. Return Pump is off
  // First 15 minutes after feeding mode stops. Smart_NTM
} else if (now()-feeding<4500) { // 15 minutes plus 1 hour
  // Continue NTM for the next 60 minutes (75 minutes total)
} else {
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
Paulturner911 wrote:Thanks Lee. We had everything correct until we stepped over to the DC Pump Control :X ....
Yeah, the introduction of ReefAngel.DCPump.FeedingSpeed setting I believe was overriding what we were trying to do. This statement helped me to realize the issue. Crossed fingers...
Paulturner911
Hats off my friend!!!! It WORKS :). Thank you so very much!
I've been working 2 days straight... otherwise I would be happier than I am. :)
Awesome!!!
For those following along... I made this a tiny bit more generic than Paul's but here is the relevant code for random modes each day. After feeding mode ends, Smart_NTM will be active for 1 hour. There's a night mode setting from 10:30pm to 8:30am.
Enjoy.
static int rmode;
changeMode=false;
if (now()-feeding<3600) {
  // Continue NTM for the 60 minutes
} else {
ganjero
Post by ganjero »
Lee,
where do you set the max and min speed for the modes?
Sorry to HJ Paul.
They are hard coded. You can adjust duration of the pulse modes in the portal.
Lee;
I put the snippet you wrote for my system in the code today and uploaded it.
the only thing I changed was the times that the random modes are on.
Instead of 8:30am-10:30pm I made it 12pm (noon) to 10pm.
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { ReefCrest, TidalSwell, ShortPulse, NutrientTransport, Else };
changeMode=false;
  if (rmode==Else) {
    ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),20,true );    // ElseMode on sync mode, Portal Speed Setting +/- 20%
  } else {
} else {
I have the portal set to Custom Speed of 50% and a duration of 20% (I know duration is hard coded and not effected by the portal).
1st) I've re-booted the unit twice and each time it starts with Short Pulse mode (as shown in the Portal) I don't know if the mode shown in the DC Pump section of the portal is the actual mode it is in or not.
2nd) It seems as if my WP-25 (Daylight Dimming Port) is running at the correct speed, but the WP-40 (Actininc Dimming Channel) reads 0 (I'm not at home so I can't tell if it is actually running or not right now).
If your in Custom mode then it's going to choose a custom mode from the list. The active mode should show in the top section. Confirm that you have Custom in the Internal Memory section...
The random function isn't that random especially if you haven't seeded it with anything (advanced topic) So anytime the controller reboots it should choose the same mode... Later other random functions should get called and it should get a more real random function...
For your other question... in short pulse mode, one pump is going to be 0 and the other pump is going to be at whatever speed. The portal is only going to catch one situation. What does it seem the ports are doing (not from the portal...) when you get a chance to see in person...
lnevo wrote:If your in Custom mode then it's going to choose a custom mode from the list. The active mode should show in the top section. Confirm that you have Custom in the Internal Memory section...
Yes it is in Custom Mode. I set it 2 or 3 times just to make sure, changing modes in between.
The active mode showing in the top section seems to be correct (it is showing Short Pulse in the top section of DC Pump area)
I will check the ports when I get home, but from your explanation it looks like the Short Pulse is working correctly.
One port is 0 (as you said) and the other port is 50% that I set it at in the portal.
If that is the case I may remove the short pule or switch my ports to have the WP-40 on the Daylight Port since that is my main pump.
Don't think it will matter..it's a timing thing...in short pulse mode its back and forth within milliseconds...
The Actinic Dimming Channel (The WP-40) is not running at all.
