I've been following this thread, because I want to set this up eventually and I saw this..lnevo wrote:Im baffled here too...between you and sacohen i feel like im losing my mind....
Sorry man.
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit | Port8Bit;
ReefAngel.DayLights( Port1 ); // Return Pump
ReefAngel.StandardFan( Port2 ); // Canopy Fans
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
//Port 6 NOT USED (Possibly Skimmer)
ReefAngel.DayLights( Port7 ); // MH 1
ReefAngel.DayLights( Port8 ); //MH 2
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 4, MoonPhase() );
ReefAngel.PWM.SetChannel( 5,(0) );
ReefAngel.PWM.SetChannel( 5, MoonPhase() );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 60sec @ 11pm-12pm (every 15min)
if (hour() >=23 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<60);
//Kalk Stir 12pm-1pm
if (hour() >=12 & hour() < 13)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Off(Port5);
///// Place your custom code below here
// Add random mode if we set to Mode to Custom in portal
static int rmode;
byte modes[] = { ReefCrest, TidalSwell, ShortPulse, NutrientTransport };
if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
changeMode=false;
static boolean feedingStarted;
static unsigned long feeding;
if (ReefAngel.DisplayedMenu==FEEDING_MODE && !feedingStarted) {
feedingStarted=true;
feeding = now();
} else {
feedingStarted=false;
// Feeding Mode is 30 minutes
if (now()-feeding<=900) {
// First 15 minutes after feeding mode. Pump is off
ReefAngel.DCPump.Speed=0;
} else if (now()-feeding<=900+3600)) {
// NTM after 15 minutes for the next 60 minutes
ReefAngel.DCPump.Mode=NutrientTransport;
ReefAngel.DCPump.Speed=InternalMemory.DCPumpSpeed_read(); // Resume previous speed
// Night mode (go to 30%)
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
ReefAngel.DCPump.Mode=Constant;
ReefAngel.DCPump.Speed=30;
} else if (InternalMemory.DCPumpMode_read()==11) {
ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
} else {
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
} else if (now()-feeding<=(900+3600)) { Code: Select all
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
feeding = now();
} else {
} else {
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
}Code: Select all
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
if (ReefAngel.DisplayedMenu!=FEEDING_MODE) feedingStarted=false;
feeding = now();
} else {
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
if (now()-feeding<900) {
// First 15 minutes after feeding mode stops. Return Pump is off
// First 15 minutes after feeding mode stops. Smart_NTM
} else if (now()-feeding<4500) { // 15 minutes plus 1 hour
// Continue NTM for the next 60 minutes (75 minutes total)
} else {
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
Yeah, the introduction of ReefAngel.DCPump.FeedingSpeed setting I believe was overriding what we were trying to do. This statement helped me to realize the issue. Crossed fingers...Paulturner911 wrote:Thanks Lee. We had everything correct until we stepped over to the DC Pump Control :X ....
static int rmode;
changeMode=false;
if (now()-feeding<3600) {
// Continue NTM for the 60 minutes
} else {
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { ReefCrest, TidalSwell, ShortPulse, NutrientTransport, Else };
changeMode=false;
if (rmode==Else) {
ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),20,true ); // ElseMode on sync mode, Portal Speed Setting +/- 20%
} else {
} else {
}lnevo wrote:If your in Custom mode then it's going to choose a custom mode from the list. The active mode should show in the top section. Confirm that you have Custom in the Internal Memory section...
The random function isn't that random especially if you haven't seeded it with anything (advanced topic) So anytime the controller reboots it should choose the same mode... Later other random functions should get called and it should get a more real random function...
For your other question... in short pulse mode, one pump is going to be 0 and the other pump is going to be at whatever speed. The portal is only going to catch one situation. What does it seem the ports are doing (not from the portal...) when you get a chance to see in person...
