rimai wrote:Yes, the Portal. The link is on the top of the page, but here it is:
http://forum.reefangel.com/portal.php
It will work if you have your wifi attachment setup and sending data to the server.
If you have the WL all ready to go, you can just add this to your loop() section of your code:
ReefAngel.WaterLevelATO(Port1,60,32,35);
The code above will use port1 to control your ATO pump with 60 seconds timeout and will maintain the level between 32% and 35%.
this is my code that the RA generated soo now where do i feed the code that you gave ??
also i want it to be in port 7 not in port 1
thanks
ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port6Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port1,17,0,21,0 );
ReefAngel.StandardLights( Port2,17,0,21,0 );
ReefAngel.DCPump.SetMode( ShortPulse,20,10 );
ReefAngel.Portal( "jack" );
int x,y;
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,49,54, "SAL:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.Salinity,COLOR_DARKKHAKI,73,54, 10 );
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,75, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,75, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
// Date and Time
