Moonlights
ecam
Moonlights
Post by ecam »
I was using this code to control my moonlights in my Ai sols
// ReefAngel.AI.SetChannel( RoyalBlue, PWMParabola(9,0,20,0,15,100,(MoonPhase()/5)<3 ? 3:MoonPhase()/5) );
I am now using the
Daylight dimming module for the dimming port and an LED stunner. How can i incorprate that code into this from the Reef Angel set-up tool
Re: Moonlights
That works, but how did you get the LED stunner to dim with RA?
ecam
Re: Moonlights
Post by ecam »
I did some reseacrh and found out that they could be dimmed on the APEX. And i figured anything that controler can do it RA can do andthen some.... So i purchased this
http://www.amazon.com/gp/product/B006G0 ... UTF8&psc=1
striped the power sure and ran the connections to the dimmer port....
(*please note: this driver will not work without a 0-10V controller (such as Apex w/ VDM, or ReefKeeper w/ ALC).) which is 0-10. I tested it last night and it lights up just fine. Tonight I will find out how well it dims it.
ecam
Re: Moonlights
Post by ecam »
My question previously is that I want to but the same parameters in this code
that i used for the AI sol RB.. is that possible
where does this part code in within the moonphase COMMAND
Re: Moonlights
Ahh, you got a meanwell driver :)
Yes, the code you posted works, but it will just do moonphase. Do you also want to do the parabola?
ecam
Re: Moonlights
Post by ecam »
Yes. I do.
Re: Moonlights
ReefAngel.PWM.SetDaylight( PWMParabola(9,0,20,0,15, MoonPhase(),0 );
I think that should do it. I left the 15 because i think thats the lowest the meanwells go before turning off..
ecam
Re: Moonlights
Post by ecam »
Where do i put that code for the moonlights? i keep gettin exepcted ) token when compliing
#include <DS1307RTC.h>fafa
#include <RF.h>fa
  byte myRFMode=0;
    byte myRFDuration=0;
    byte myRFSpeed=0;
ReefAngel.WaterChangePorts = Port1Bit | Port8Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
  ReefAngel.FeedingModePorts = Port1Bit | Port6Bit | Port8Bit; // Turn off Ports 1, 6, 7 and 8 when Water Change Mode is activated
  ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit| Port5Bit;
  ReefAngel.OverheatShutoffPorts = Port2Bit |Port3Bit | Port4Bit | Port5Bit | Port7Bit; // Turn off Ports 3,
    // Setup ATO Port for AI communication
    ReefAngel.AI.SetPort( lowATOPin );
    ReefAngel.Relay.On( Box1_Port2 );  // Razor Led
    ReefAngel.Relay.On( Box1_Port4 ); // Sump Equipment - UV, Pump
    ReefAngel.Relay.On( Box1_Port5 ); // MP40s
    ReefAngel.Relay.On( Box1_Port6 ); // JBJ
  //  Port1 Return pump...  on all the time!!!
      ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port4 ) ); //Refuge
  //  Port3 Return pump...  not used
      ReefAngel.StandardLights( Port4,10,0,20,0 ); //ATI Actinic
      ReefAngel.StandardLights( Port5,11,0,19,0 );  //ATI Daylight
      ReefAngel.StandardLights( Port6,10,0,20,0 );  //ATI Fan
      ReefAngel.StandardHeater( Port7,778,790 ); //Heater
      ReefAngel.Relay.DelayedOn( Port8,2 ); //Skimmer
      ReefAngel.Relay.Off( Box1_Port7); // Lunar Hub          Port #9
 //   Box1_Port2 Razor_LED (Sump)...  on all the time!!!      Port #10
      ReefAngel.Relay.Off( Box1_Port3); // Start with the relay off
              if (hour()>=5 && hour()<10) ReefAngel.Relay.On(Box1_Port3); // Moonlight Between 5-10am turn the relay on
              if (hour()>=20 && hour()<=23) ReefAngel.Relay.On(Box1_Port3); // From 8pm-Midnight turn the relay on
 //   Box1_Port4 Ecotech MP_40 Pumps  on all the time!!!      Port #12
 //   Box1_Port5 Razor_LED (Sump)...  on all the time!!!      Port #13
 //   Box1_Port6 JBJ ATO ...          on all the time!!!      Port #14
     ReefAngel.Relay.Off( Box1_Port7);  // ALK Doser ...      Port #15
     ReefAngel.Relay.Off( Box1_Port8);  // Calc Doser ...     Port #16
 ReefAngel.PWM.SetDaylight(PWMParabola(9,0,20,0,15, MoonPhase(),0 );
//    ReefAngel.AI.SetChannel( White, PWMParabola(11,0,17,0,0,75,0) );
//    ReefAngel.AI.SetChannel( Blue, PWMParabola(9,0,20,0,15,100,0) );
    ReefAngel.RF.SetMode( ReefCrest,85,10 );
  //  ReefAngel.RF.SetChannel( Radion_White, PWMParabola(9,0,20,0,0,60,0) );
  //  ReefAngel.RF.SetChannel( Radion_RoyalBlue, MoonPhase() );
  //  ReefAngel.RF.SetChannel( Radion_Red, PWMParabola(9,0,20,0,15,65,15) );
  //  ReefAngel.RF.SetChannel( Radion_Green, PWMParabola(9,0,20,0,15,50,15) );
  //  ReefAngel.RF.SetChannel( Radion_Blue, MoonPhase() );
 //   ReefAngel.RF.SetChannel( Radion_Intensity, PWMParabola(9,0,20,0,15,94,15) );
  //  if ( second()==0 ) ReefAngel.RF.RadionWrite();
      if (hour()>=6 && hour()<11)
        myRFSetMode(ReefCrest,85,10);
      else if (hour()>=11 && hour()<13)
      else if (hour()>=13 && hour()<16)
        myRFSetMode(Smart_NTM,85,15);
      else if (hour()>=16 && hour()<19)
        myRFSetMode(ReefCrest,65,10);
        myRFSetMode(Lagoon,40,10);
    // Hardcode PH calibrations
     //ReefAngel.PHMin=544; // PH7.0
     //ReefAngel.PHMax=830; // PH10.0
    ReefAngel.Portal( "ecam" );
    int x,y;
    // Aqua Illumination
    x = 10;
    y = 20;
    ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x,y,"WH:" );
    ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+38,y,"BL:" );
    ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+76,y,"RB:" );
    for ( int a=0;a<3;a++ )
      ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+18,y,ReefAngel.AI.GetChannel(a) );
      x += 38;
    // Parameters
    ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
    // Main Relay Box
    // Date and Time
    void myRFSetMode(byte m, byte s, byte d)
      if (m!=myRFMode || s!=myRFSpeed || d!=myRFDuration || millis()<5000)
        myRFMode=m;
        myRFSpeed=s;
        myRFDuration=d;
        ReefAngel.RF.SetMode(m,s,d);
Re: Moonlights
I missed a ) before the ;
ecam
Re: Moonlights
Post by ecam »
Just rememebered that might first box is analog dimming....
ReefAngel.PWM.SetDaylight(PWMParabola(20,0,23,0,0, MoonPhase(),0 ));
assuming this wont work....
Can i change it to analog?
Here are the specs.....
http://www.meanwell.com/search/eln-60/ELN-60-spec.pdf
is it digital or analog?
Also roberto, since i recently brought a new relay. does that mean that all i hav eto do is switch my boxes (assuming the new default is pwm) in the the head unit and then i will have PWM?
Re: Moonlights
It makes no difference pwm or analog. Same code.
ecam
Re: Moonlights
Post by ecam »
I tried 0 , 10 , 20, and 100. They all look the same. It's not getting the dimming signal
Re: Moonlights
If you just put the moonphase() function does it work?
Are you in the daylight port or actinic?
ecam
Re: Moonlights
Post by ecam »
Daylight port
ecam
Re: Moonlights
Post by ecam »
Just switch to moon phase. No change
Re: Moonlights
Can you measure the voltage in the dimming ports?
ecam
Re: Moonlights
Post by ecam »
rimai wrote:Can you measure the voltage in the dimming ports?
Ok... ill put my volt meter on it when i get home.
ecam
Re: Moonlights
Post by ecam »
These are still not dimming. Im goign to convert to memory and send different signals to see if i can get it to work.
How do I take the dimming channel current?
