Sacohen's Current code
This is a copy of my current code basically as a backup, but feel free to look over it and use what you may feel fits your needs.
The system includes...
RA +
Relay(original included)'
PH Probe
Standard ATO High and Low
Expansion Hub
Dimming Expansion
RANet and Relay
Water Level Expansion
Multi Water Level Expansion
Salinity Expansion
ATO Pump
WiFi module
Bluetooth module
3 Jebao Cables (WP-25, WP-40, DC-12000pump)
3 Temp Sensors
Dimmable Lunar Hub & 2 Moonlights
Basic control of the following.
Daylight
Actinic
Moonlight
Pumps
2 Jebao pumps (WP40 & WP25)
Control of my NatuReef DeNitrification chamber.
(Thanks to lnevo for help with this coding)
Random Jebao modes that lnevo did for PaulTurner911.
12/21/13
Changed the Speed for the Jebao pumps from 30% to 0% during feeding.
3/22/14
Added AutoFeeder triggered by Reef Angel.
How to modify the Eheim 3581 are here. http://wamas.org/forums/blog/13/entry-4 ... ontroller/
Added Dimmable Lunar Hub. Right now I'm just using the MoonPhase with an on and off time that coincide with my lighting. I added a slope to it so it seems like a moonrise and set
4/8/14 Added some code to turn a pump on every 8 hours for 15 min to stir my Kalkwasser.
5/26/14 Removed code to mix Kalkwasser.
8/1/14 Modified the Denitrification code to use variables instead of hard times. (Thanks to lnevo again for this)
8/4/14 Added Kalk Mixing Code. When the ATO reservoir is at 100% or above the pump in the reservoir turns on for 1 hr to mix the Kalkwasser in the reservoir and then turns off to let the unsaturated Kalk settle to bottom before use as ATO water.
9/11 Updated code for 1.1.1 Libraries. Added DNS server name and Server Authentication. Removed the Else Mode wave function code since it is now incorporated in to the libraries and added the Gyre Wave mode to the choice of Random Waves. Made some slight changes to the ATO code that had to be done because of the new libraries.
1/26/15 Added RA Net and Relay.
2/27/15 Added code to auto flush my RO/DI unit Monday, Wednesday and Friday using a 12V DC 1/2" Normally Closed Pneumatic Plastic Air Water Electric Solenoid Valve.
7/05/15 Added 2 Evergreen D120 LED lights. Modded for RA Dimming control and set up and East to West Sunrise/Sunet code.
#include <SoftwareSerial.h>
// Define Relay Ports by Name
#define Actinic_Lights     1
#define Day_Lights         2
#define Kalkwasser         3
#define Pumps              4
#define Unused             5
#define DeNit_Doser        6
#define DeNit_Pump         7
#define ATO_Pump           8
#define Unused             Box1_Port1
#define Feeder             Box1_Port2
#define Unused             Box1_Port3
#define Unused             Box1_Port4
#define Unused             Box1_Port5
#define Flush_Bypass       Box1_Port6
#define Main_RODI          Box1_Port7
#define Dummy              Box1_Port8
// Does not need to be global.
// unsigned long ATOUpdate=0;
static time_t LastATO=millis();    // For de-bounced ATO
ReefAngel.WaterChangePortsE[0] = Port1Bit;
//Set Standard Menu
ReefAngel.AddStandardMenu();
//Water Level
ReefAngel.AddMultiChannelWaterLevelExpansion();
//Webserver Authentication
ReefAngel.Network.WifiAuthentication("Sacohen:xxxxxxxx");
//DDNS Server
ReefAngel.DDNS("myreeftank");
ReefAngel.AddRANet();
ReefAngel.DCPump.ActinicChannel=Sync; // Now you're pump will be affected by the portal settings.
//ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
//ReefAngel.DCPump.AntiSyncOffset=85;
ReefAngel.Relay.On( Pumps );
ReefAngel.Relay.On( Dummy );
  ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
  ReefAngel.StandardLights( Day_Lights,12,30,21,0 );
  //East to West Sunrise/Sunset Dimming
    ReefAngel.PWM.SetChannel( 0, PWMSlope(12,30,20,30,0,100,60,0) );
    ReefAngel.PWM.SetChannel( 1, PWMSlope(12,0,21,30,0,100,60,0) );
    ReefAngel.PWM.SetChannel( 2, PWMSlope(13,0,21,0,0,100,60,0) );
    ReefAngel.PWM.SetChannel( 3, PWMSlope(12,30,22,0,0,100,60,0) );
  // *******************  Debounced ATO code. Activate ATO no more than every 30 seconds.  *******************
//if (ReefAngel.WaterLevel.GetLevel(0) < 34) LastATO=millis();    // Start a timer
//if (millis()-LastATO<30000 && millis()-LastATO>10)     // Has it been less than 30,000 ms? (30 secs)
//  ReefAngel.Relay.Off(ATO_Pump);                         // If so, make sure the topoff pump is off
//  else
    ReefAngel.WaterLevelATO(0,ATO_Pump,720,34,36);                     // Otherwise, use the normal topoff routine.
  if ( hour()>=13 && hour()<21 )
  ReefAngel.PWM.SetChannel( 5, 0 );
  ReefAngel.PWM.SetChannel( 5, PWMSlope(21,0,13,0,0,MoonPhase() ,60,0) );
  //Flush RO/DI Membrane Monday, Wednseday and Friday times a week @ 9pm.
ReefAngel.Relay.Off(Main_RODI);
if (weekday()==dowMonday && hour()==21 && minute()<5)
  ReefAngel.Relay.On(Main_RODI);
if (weekday()==dowWednesday && hour()==21 && minute()<5)
if (weekday()==dowFriday && hour()==21 && minute()<10)
ReefAngel.Relay.Off(Flush_Bypass);
if (weekday()==dowFriday && hour()==21 && minute()>=05 && minute()<10)
  ReefAngel.Relay.On(Flush_Bypass);
  //Mix Kalkwasser
static unsigned long Kalk_Mixing = 0;
static unsigned long stopTime = 0;
static byte prevWL=0;
if (ReefAngel.WaterLevel.GetLevel(1)==100 && prevWL<100) {
  stopTime=now()+7200; // Get time one hour from now.
prevWL = ReefAngel.WaterLevel.GetLevel(1); // Store the water level
if (now() < stopTime) { ReefAngel.Relay.On(Kalkwasser); } else { ReefAngel.Relay.Off(Kalkwasser); }
  //AutoFeeder
static unsigned long autofeeding = 0;
if ((now()%SECS_PER_DAY==64800)) //if it is 6 pm
ReefAngel.FeedingModeStart(); //START FEEDING MODE
if ( autofeeding == 0 ) {
autofeeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-autofeeding>=60) && (now()-autofeeding<=61)) //if between 60 and 61 seconds has past
ReefAngel.Relay.On(Feeder); //TURN FEEDER RELAY ON
ReefAngel.Relay.Off(Feeder); //TURN FEEDER RELAY OFF
} else {
if ( autofeeding > 0 ) {
autofeeding = 0;
  // DeNitrate Routine
int DeNit_Offset=3600;
int DeNit_Repeat=21600;
int DeNit_Doser_Offset=1200;
int DeNit_Doser_Runtime=600;
int DeNit_Pump_Runtime=1200;
int DeNit_ATO_Offtime=1500;
// Pump comes on first
ReefAngel.Relay.Set(DeNit_Pump,(now()-DeNit_Offset)%DeNit_Repeat<DeNit_Pump_Runtime);  // Runs denitrator pump
// Doser comes on second
ReefAngel.Relay.Set(DeNit_Doser,((now()-DeNit_Offset)-DeNit_Doser_Offset)%DeNit_Repeat<DeNit_Doser_Runtime); // Runs denitrator doser
  // Disable ATO
if ( (now()-3600)%21600<DeNit_ATO_Offtime) ReefAngel.WaterLevelATO(0,ATO_Pump,720,0,1);
  // Delay WL ATO after water change and DeNit_Dosing
  static time_t wcTimer=0;
  if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) wcTimer=now();
  // First 10 minutes after WC disable ATO
  if (now()-wcTimer >= 0 && now()-wcTimer < 600)
    // Track Salinity low duration
    static unsigned long lastGoodSal;
    static boolean lowSalFlag;
    // Salinity is good, update counter
    if (ReefAngel.Params.Salinity>=335) lastGoodSal=now();
    // Counter hasn't been updating in 300 seconds..
    if (now()-lastGoodSal>300) {
      lowSalFlag=true; // Salinity is definitely below 33.5
    } else {
      lowSalFlag=false; // Salinity back to normal
    // Disable ATO if lowSalFlag is true
   //if (lowSalFlag) ReefAngel.WaterLevelATO(0,ATO_Pump,720,0,1);
  // Disable ATO if ATO High IsActive()
// Add random mode if we set to Mode to Custom in portal
static int rmode;
byte modes[] = { ReefCrest, Gyre, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else, };
if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
changeMode=false;
static unsigned long feeding;
if (now()-feeding<3600) {
  // Continue NTM for the 60 minutes
  ReefAngel.DCPump.Mode=NutrientTransport;
} else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.Mode=Constant;
  ReefAngel.DCPump.Speed=30;
} else if (InternalMemory.DCPumpMode_read()==11) {
  ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
} else {
  ReefAngel.Portal( "Sacohen","xxxxxxxx" );
int x,y;
// Parameters
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,57, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,57, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,66,66, "WL 1:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel(1) );
//Salinity
  strcat(text,"  ");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,39,75,"Salinity:");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,99,75,text);
// Main Relay Box
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
// Date and Time
nrosdal
Re: Sacohen's Current code
Post by nrosdal »
Hey Steve,
If i paste your entire code in the arduino and connect my RA and upload. WIll it just effect my jebaos? or will it make all my outlets the same as yours? sorry, very new here and haven't figured much out yet but want to get pumps going.
Nick
It will make all your outlets the same as mine. Not only the outlets, but the WiFi, portal, everyting
Nick;
If you want to use the random code you will need the following parts in red.
#define Unused 3
#define Pumps 4
#define Sump_Fan 5
#define Unused 8
#define ATO_Pump Box1_Port1
#define Moon_Lights Box1_Port2
#define Unused Box1_Port6
#define Unused Box1_Port7
//Set Standard Menu
ReefAngel.StandardLights( Day_Lights,13,0,21,0 );
ReefAngel.StandardLights( Sump_Fan,13,0,21,0 );
ReefAngel.WaterLevelATO(ATO_Pump,720,31,34);
ReefAngel.Relay.Set( Moon_Lights, !ReefAngel.Relay.Status( Actinic_Lights ) );
int DeNit_Doser_Runtime=1200;
ReefAngel.Relay.Set(DeNit_Pump,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
ReefAngel.Relay.Set(DeNit_Doser,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
// Disable ATO
if ( (now()-3600)%21600<1500) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
} else {
if (lowSalFlag) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else };
changeMode=false;
if (rmode==Else) {
ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),20,true ); // ElseMode on sync mode, Portal Speed Setting +/- 20%
} else {
} else {
ReefAngel.Portal( "Sacohen","********" );
int x,y;
// Parameters
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel() );
strcat(text," ");
// Main Relay Box
// Date and Time
static unsigned long LastChange=millis(); // Set the inital time that the last change occurred
static int Delay = random( 500, 3000); // Set the initial delay
static int NewSpeed = MidPoint; // Set the initial speed
static int AntiSpeed = MidPoint; // Set the initial anti sync speed
if ((millis()-LastChange) > Delay) // Check if the delay has elapsed
Delay=random(500,5000); // If so, come up with a new delay
int ChangeUp = random(Offset); // Amount to go up or down
if (random(100)<50) // 50/50 chance of speed going up or going down
LastChange=millis(); // Reset the time of the last change
if (WaveSync)
return NewSpeed;
return AntiSpeed;
Ademster
Post by Ademster »
How do I use the code you have provided for the jaebo pumps but only for 1 pump?
so it would alternate and be random through out the day, but go to min setting for feeding, and off for water changes,
Adam
58 Gal
Actually that code is for the old libraries that do not have Else mode built into them.
I'll need a little time to go through my current code and highlight what you need and what to remove for a single pump.
I'll try to get it put up today.
Ademster
Post by Ademster »
That be awesome!!! Thanks
do you want me to pm you my current code?
Adam
58 Gal
#include <Wire.h>fF
#include <RA_NokiaLCD.h>f
#define Pumps 4
#define Sump_Fan 5
#define ATO_Pump 8
//Set Standard Menu
//Water Level
//ReefAngel.Network.WifiAuthentication("Sacohen:S3tho31o");
//DDNS Server
//Remove this part for single pump
ReefAngel.DCPump.AntiSyncOffset=100;
ReefAngel.WaterLevelATO(0,ATO_Pump,720,28,31);
//Mix Kalkwasser
if (ReefAngel.WaterLevel.GetLevel(1)>=100 && prevWL<100) {
stopTime=now()+3600; // Get time one hour from now.
//AutoFeeder
} else {
autofeeding = 0;
// Disable ATO
} else {
static int rmode;
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else, Gyre };
changeMode=false;
} else {
ReefAngel.Portal( "Sacohen","xxxxxxx" );
int x,y;
// Parameters
// Water Level
//Salinity
strcat(text," ");
// Main Relay Box
// Date and Time
Ademster
Post by Ademster »
thanks, I will test it later today
Adam
58 Gal
Ademster
Post by Ademster »
tried it, but it comes up with an error.
_58test.cpp: In function 'void loop()':
_58test:98: error: 'Else' was not declared in this scope
_58test:98: error: 'Gyre' was not declared in this scope
Adam
58 Gal
Ademster
Post by Ademster »
here is the whole code.
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.AddMultiChannelWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port4Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit;
    ReefAngel.Relay.On( Port7 );
     //Use PH Flexible Calibration
    ReefAngel.WaterLevelATO( Port4 );
    ReefAngel.Wavemaker1( Port5 );
    ReefAngel.DayLights( Port8 );
    ReefAngel.PWM.Channel0PWMSlope();
    ReefAngel.PWM.Channel1PWMSlope();
    ReefAngel.PWM.Channel2PWMSlope();
    ReefAngel.PWM.Channel3PWMSlope();
    ReefAngel.PWM.Channel4PWMSlope();
static int rmode;
changeMode=false;
} else {
    ReefAngel.Portal( "ademster" );
Adam
58 Gal
Ademster
Post by Ademster »
Here is the libraries version
Reef Angel Libraries Found: Development
Reef Angel Libraries Version: 1.1.0
Adam
58 Gal
This is for the developmental code (11).
For the currently released code (10) the original post that was in red will work.
The part to remove would be the same part that is in blue.
Ademster
Post by Ademster »
Still same error with
ElseMode
Adam
58 Gal
Are you using the the libraries that are part of the Arduino Controller or did you go to GitHub and download the dev libraries from there (https://github.com/reefangel/Libraries/archive/dev.zip)?
Ademster
Post by Ademster »
part of arduino, didn't know I had to download from github..
NVM, i figuired it out
Adam
58 Gal
You don't have to download the dev files.
You are either using the currently released version the Roberto had tweaked, approved and release or you are using a beta version that people are adding things to and making adjustments.
Glad you got it working.
Please post what you did to get it working so others can benefit from it.
pandimus
Post by pandimus »
Sacohen wrote:This is a copy of my current code basically as a backup, but feel free to look over it and use what you may feel fits your needs.
RA +
Expansion Hub
Dimming Expansion
Power Control Expansion
Salinity Expansion
ATO Pump
WiFi module
Bluetooth module
2 Jebao Cables (WP-25, WP-40)
3 Temp Sensors
Daylight
Actinic
Moonlight
Pumps
12/21/13
3/22/14
2/27/15 Added code to auto flush my RO/DI unit 3 times a week.
#define Pumps              4
#define Unused             5
#define ATO_Pump           8
//Set Standard Menu
//Water Level
//DDNS Server
  //Flush RO/DI Membrane 3 times a week @ 9pm.
ReefAngel.Relay.Set(Main_RODI,(now()+10800)%(SECS_PER_DAY*3)<300);
  //Mix Kalkwasser
  //AutoFeeder
} else {
autofeeding = 0;
  // Disable ATO
    } else {
static int rmode;
changeMode=false;
} else {
int x,y;
// Parameters
// Water Level
//Salinity
  strcat(text,"  ");
// Main Relay Box
// Date and Time
sorry steve couldn't find it, but what valve did you use to flush your ro/di?
I got a 1/2" Normally Closed Pneumatic Plastic Air Water Electric Solenoid Valve 12V DC off Ebay (http://www.ebay.com/itm/1-2-Inch-Normal ... 1c4fff435f) plumbed it into my line that feeds my RO/Di system and then plugged it into my RANet Relay in the garage.
I got the 12v version because I was originally going to run Cat 5 wir back to my 12v Power Expansion module and running from there, but I had problems with the power expansion module and when Roberto released the RANet Relay I got that instead.
The valve is just running ordinary house water thru it so you don't need to worry about it being OK for salt water and corrosion.
This is the code I'm using to turning on 3 days a week for 5 min at 9PM.
I'm trying to figure out how to get it to run Monday, Wednesday and Friday rather than every 3 days.
Roberto gave me this for 3 specific days, but it didn't seems to work.
ReefAngel.Relay.Set(Main_RODI, ((weekday()==dowMonday || weekday()==dowWednesday || weekday()==dowFriday) && (now()+10800)<300 ));
I'm not real good at coding so I can't figure out why it wasn't working.
slm222
Post by slm222 »
is there a way to have a random mode from, lets say, 10 am to 6 pm and then run a set mode over night?
That's the way mine is setup.
It is random from Noon to 10pm and then constant 30% from 10 pm to noon.
I'll look at the code closer when I get in front of my laptop, but honestly I'm not a coder. Lnevo wrote it for me and it is a modification of code he wrote for PaulTurner911.
