Standard dimming port
Winschuc
Post by Winschuc »
Can someone point me in the direction of a walk through for the standard dimming ports? I'm having trouble locating an east to follow walk through.
I'm in the process if connecting my 2 100w multi-chips and my 50w actinic.
Winschuc
Re: Standard dimming port
Post by Winschuc »
I just need to know how to connect the drivers to the standard dimming ports. I'm really lost and dont want to run the risk of doing it wrong and frying my RA.
You need the dimming lead connectors and then there should be a dim+ and a dim- from your driver. Connect those to the dimming lead.
Winschuc
Post by Winschuc »
Just solder them on there?
You can start with an easy splice till you know it's working right but yeah, solder when you're done.
