Reef Angel Malfunctioning
Re: Reef Angel Malfunctioning
Yes, same problem. It's related to the expansion bus signal.
The 2 modules that can do that are the old dimming module and the RF module.
But if you replaced the twi.c, you should not see the controller blinking and the time changing. Your controller should reboot instead.
I'm thinking some interference noise is causing your RF module to lockup, which causes all that.
ecam
rimai wrote:Yes, same problem. It's related to the expansion bus signal.
What kind of interference, am i looking for?
I haven't really added any electric devices in my tank area, expect for the new MP40s and your new modules
ecam
rOBERTO I RAN THIS UPDATE I SAW THE INITIAL 3 LIGHT FLASH AND THE ENDING AND NOTHING IN BETWEEN.. dID IT WORK?rimai wrote:To use the new code, you will need to return the RF module to the original firmware.
ecam
Roberto just happened again with the old firmware restored. Any other ideas?
Did you load the code I posted?
Does it work ok without the RF module?
ecam
Dont understand the question.. but will try to answer a few possible version;
When the RF module fails. It puts my RA into a flashing red status on the head unit at which points it no longer takes instructions. whatever it is doing at the time of the freeze will continue. (i.e: my lights were on for over 18 hrs one day!!!! i disconnect the module and everything goes back o normal.
ecam
#include <DS1307RTC.h>fafa
#include <RF.h>fa
byte myRFMode=0;
byte myRFDuration=0;
byte myRFSpeed=0;
ReefAngel.WaterChangePorts = Port1Bit | Port8Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
ReefAngel.FeedingModePorts = Port1Bit | Port6Bit | Port8Bit; // Turn off Ports 1, 6, 7 and 8 when Water Change Mode is activated
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit| Port5Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit |Port3Bit | Port4Bit | Port5Bit | Port7Bit; // Turn off Ports 3,
// Setup ATO Port for AI communication
// ReefAngel.AI.SetPort( lowATOPin );
ReefAngel.Relay.On( Box1_Port2 ); // Razor Led
ReefAngel.Relay.On( Box1_Port4 ); // Sump Equipment - UV, Pump
ReefAngel.Relay.On( Box1_Port5 ); // MP40s
ReefAngel.Relay.On( Box1_Port6 ); // JBJ
// Port1 Return pump... on all the time!!!
ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port4 ) ); //Refuge
// Port3 ... not used
ReefAngel.StandardLights( Port4,10,0,20,0 ); //ATI Actinic
ReefAngel.StandardLights( Port5,11,0,19,0 ); //ATI Daylight
ReefAngel.StandardLights( Port6,10,0,20,0 ); //ATI Fan
ReefAngel.StandardHeater( Port7,778,790 ); //Heater
ReefAngel.Relay.DelayedOn( Port8,2 ); //Skimmer
//box 2
ReefAngel.Relay.Off( Box1_Port1); // Lunar Hub Not used Port #9
// Box1_Port2 Razor_LED (Sump)... on all the time!!! Port #10
ReefAngel.Relay.Off( Box1_Port3); // Start with the relay off Port #11
if (hour()>=5 && hour()<10) ReefAngel.Relay.On(Box1_Port3); // Moonlight Between 5-10am turn the relay on
if (hour()>=20 && hour()<=23) ReefAngel.Relay.On(Box1_Port3); // From 8pm-Midnight turn the relay on
// Box1_Port4 Ecotech MP_40 Pumps on all the time!!! Port #12
// Box1_Port5 Razor_LED (Sump)... on all the time!!! Port #13
// Box1_Port6 JBJ ATO ... on all the time!!! Port #14
ReefAngel.Relay.Off( Box1_Port7); // ALK Doser ... Port #15
ReefAngel.Relay.Off( Box1_Port8); // Calc Doser ... Port #16
// ReefAngel.PWM.SetDaylight(PWMParabola(20,0,23,0,0, MoonPhase(),0 ));
// ReefAngel.AI.SetChannel( White, PWMParabola(11,0,17,0,0,75,0) );
// ReefAngel.AI.SetChannel( Blue, PWMParabola(9,0,20,0,15,100,0) );
// ReefAngel.AI.SetChannel( RoyalBlue, PWMParabola(9,0,20,0,15,100,(MoonPhase()/5)<3 ? 3:MoonPhase()/5) );
ReefAngel.RF.SetMode( ReefCrest,85,10 );
// ReefAngel.RF.SetChannel( Radion_White, PWMParabola(9,0,20,0,0,60,0) );
// ReefAngel.RF.SetChannel( Radion_RoyalBlue, MoonPhase() );
// ReefAngel.RF.SetChannel( Radion_Red, PWMParabola(9,0,20,0,15,65,15) );
// ReefAngel.RF.SetChannel( Radion_Green, PWMParabola(9,0,20,0,15,50,15) );
// ReefAngel.RF.SetChannel( Radion_Blue, MoonPhase() );
// ReefAngel.RF.SetChannel( Radion_Intensity, PWMParabola(9,0,20,0,15,94,15) );
// if ( second()==0 ) ReefAngel.RF.RadionWrite();
// Define Your dosing pumps
#define numDPumps 2
byte pumpRelays[numDPumps]={ Box1_Port7, Box1_Port8 };
int DPVolume[numDPumps]={ 30, 30 } ; // 30ml for each alk and calcium
int DPRepeat[numDPumps]={ 60, 60 } ; // Repeat every 60 miniutes
// Define Calibration here
int CalTime[numDPumps]={ 600, 600 }; // 10 minutes / 10 minutes
int CalVol[numDPumps]={ 350, 300 }; // 350ml / 300ml
// Function: RunDosingPumps()
void RunDosingPumps() {
float rate;
int calcTime[numDPumps];
for (int i=0;i < numDPumps; i++) {
rate=(float)CalVol[i]/CalTime[i];
calcTime[i]=DPVolume[i]/rate/(1440/DPRepeat[i]);
// Run the pumps
ReefAngel.DosingPumpRepeat(pumpRelays[i], i*20, DPRepeat[i], calcTime[i]); // Offset between each pump is 20 minutes
// Display Time calculated in portal
ReefAngel.CustomVar[0]=calcTime[0];
ReefAngel.CustomVar[1]=calcTime[1];
// Function: LogDosingPumps()
void LogDosingPumps() {
static time_t pumpTimer[numDPumps];
static boolean pumpStatus[numDPumps];
float rate;
for (int i=0;i< numDPumps;i++) {
if (ReefAngel.Relay.Status(pumpRelays[i])) {
if (!pumpStatus[i]) {
pumpStatus[i]=true;
} else {
if (pumpStatus[i]) {
pumpStatus[i]=false;
// Report How much volume has been dosed per day.
// Could make this in minutes... excercise for the reader..
ReefAngel.CustomVar[2]=pumpTimer[0]*rate;
ReefAngel.CustomVar[3]=pumpTimer[1]*rate;
// Clear timer at end of day
if (now()%SECS_PER_DAY==SECS_PER_DAY-1) pumpTimer[i]=0;
if (hour()>=6 && hour()<11)
myRFSetMode(ReefCrest,85,10);
else if (hour()>=11 && hour()<13)
else if (hour()>=13 && hour()<16)
myRFSetMode(Smart_NTM,85,15);
else if (hour()>=16 && hour()<19)
myRFSetMode(ReefCrest,65,10);
myRFSetMode(Lagoon,40,10);
// Hardcode PH calibrations
//ReefAngel.PHMin=544; // PH7.0
//ReefAngel.PHMax=830; // PH10.0
ReefAngel.Portal( "ecam" );
int x,y;
// Aqua Illumination
x = 10;
y = 20;
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x,y,"WH:" );
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+38,y,"BL:" );
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+76,y,"RB:" );
for ( int a=0;a<3;a++ )
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+18,y,ReefAngel.AI.GetChannel(a) );
x += 38;
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
// Main Relay Box
// Date and Time
void myRFSetMode(byte m, byte s, byte d)
if (m!=myRFMode || s!=myRFSpeed || d!=myRFDuration || millis()<5000)
myRFMode=m;
myRFSpeed=s;
myRFDuration=d;
ReefAngel.RF.SetMode(m,s,d);
If it is still doing that, you didn't replace the twi.c correctly.
That would only happen if you didn't do it. With the one I posted earlier, the controller would reboot.
ecam
Roberto. I told you the light sequence when I uploaded. And u mentioned that it seemed like it work. Is there anyway I can ping the unit to see what version of the twi file it is running. So that we can confirm
The light sequence you mentioned was in the RF module.
I'm talking about the red status led on RA.
An easy way to know is to open the head unit and move the SDA and SCL jumpers on the head unit.
They are in the vertical position now. Moving them to the horizontal position will cause the bus to lock.
Also, I just remember you should not have the Radion code either, even if commented. The auto-feature selection is enabling the code and you are just going back to square one.
#include <RF.h>fa
byte myRFMode=0;
byte myRFSpeed=0;
{ //Port1 Return pump... on all the time!!!
ReefAngel.Relay.Off( Port3); // Start with the relay off
if (hour()>=5 && hour()<10) ReefAngel.Relay.On(Port3); // Moonlight Between 5-10am turn the relay on
if (hour()>=20 && hour()<=23) ReefAngel.Relay.On(Port3); // From 8pm-Midnight turn the relay on
int x,y;
x = 10;
y = 20;
x += 38;
// Parameters
// Main Relay Box
// Date and Time
myRFMode=m;
myRFSpeed=s;
myRFDuration=d;
ecam
So im running this code now. Removing all AI and ECOtech radion references \
#include <RF.h>fa
byte myRFMode=0;
byte myRFSpeed=0;
//box 2
RunDosingPumps();
LogDosingPumps();
// Parameters
// Main Relay Box
// Date and Time
#define numDPumps 2
int DPVolume[numDPumps]={ 3, 3 } ; // 1ml for each alk and calcium
int DPRepeat[numDPumps]={ 240, 240 } ; // Repeat every 4 hrs 5x a day
int CalVol[numDPumps]={ 350, 300 }; // 350ml / 300ml... .58 / .5
float rate;
// Run the pumps
float rate;
pumpStatus[i]=true;
} else {
myRFMode=m;
myRFSpeed=s;
myRFDuration=d;
You must remove this:
The whole idea is to not use the SetMode function and you introduced it again, which will bring you right back to square one again.
Also, make sure that your RF module is connected when you reboot the controller or it will only change mode in the next mode change time.
ecam
Done. good thing cause it was just time-travelling on me
ecam
Roberto, it appears that code did the trick. its been connected to the RA for a week with no issues. i will now put the pumps under the control of the RA and see what happens
Veeresh
Hi Guys
I got my unit last month with the following configuration
RA Plus
Expansion Hub
Expansion Relay 1
Salinity Expansion
Wifi Module
RF Module
I have having the same problem. THE RA bus lock up cause the Radion Light to stay on and the Relay box also hangs. My chiller freeze the tank to below 23 C.
The moment I unplug the RF module from the Expansion hub all revert to normal. When I connect the RF module back to the Expansion hub, I have the bus lock after several hours.
I remove the Ecotech Tech pump and radion led light code and disconnect the RF module and the problem disappears.
I also tried to recompile with the old twi.c and the bus lock still up..
Can anybody help ? Could this be hardware problem ? I did not flash the RF module with the firmware because the problem still persist according to ecam...
Veeresh
version 1.1.0
RA Plus
Expansion Hub
Expansion Relay 1
Salinity Expansion
Wifi Module
RF Module
Veeresh
version 1.1.0
Veeresh
Hi Guys
I had my Hub Expansion module replaced and he problem disappear.
No more "Bus Lock Error"
Veeresh
Just Sharing
Veeresh
Just Sharing
