Basic On/Off Function?
kirkwood
Post by kirkwood »
Every 5.5 hours I want port 5 to turn on/off. The power only needs to be cut off for a couple seconds and then turn back on.
Re: Basic On/Off Function?
Try this:
ReefAngel.Relay.Set(Port5,now()%19800==0);
kirkwood
Post by kirkwood »
1) So does Port 5 need to be listed as an "ALWAYS ON" port?
2) Do I paste the code in the custom code area?
Currently I have Port 5 set as an "ALWAYS ON" port and pasted the code in the custom code section. And now for some reason the default of Port 5 is to be OFF? So I have to mask it to turn it on. I figured that I'm doing something wrong.
You can remove the always on code if you want to. Leaving it won't do anything either... So your choice.
I misread your question. I thought you wanted the opposite :(
Try this then:
ReefAngel.Relay.Set(Port5,now()%19800!=0);
