Extra temp probes
jjdezek
Extra temp probes
Post by jjdezek »
I just got two temp probs and the salinity probe. I haven't went throug it too much but I did plug one temp probe in and it's not showing up on the portal. Do I have to do any extra programming for them?
Re: Extra temp probes
You need to reboot controller for it to initialize it..
jjdezek
Post by jjdezek »
Ok got it. Now I added the salinity probe but it seems to be reading high. I've been using a swing arm to set my salinity to 1.025 and the probe is reading 42PPT. How acurite is it right out of the box? Do I need to calibrate it or is my salinity really that high?
You need to calibrate
jjdezek
Post by jjdezek »
Ok thanks. Where would I get calibration solution?
LFS should have. Also BRS maybe. You could also follow this:
http://www.reefkeeping.com/issues/2004-06/rhf/
I use my own tank water for calibration :)
