Power supply help
jjdezek
Power supply help
Post by jjdezek »
I got a jeabo pump without the power supply and need to find one that will work on it. The standard supply is rated 1.5A input and 2.5A output, I have one that's 1.2A input and 2.5A output. Will this work or does the input need to be 1.5A?
Piper
Re: Power supply help
Post by Piper »
That should be fine as long as it's 24v at 2.5A output.
~Charlie
jjdezek
Post by jjdezek »
Yeah it's only 12V trying to find one that's 24V
Piper
Post by Piper »
You don't find 24v transformers laying around all that often. Check Amazon or one of the on-line electronic component shops like www.jameco.com or www.digikey.com.
jjdezek
Post by jjdezek »
I found one in the closet that's 24V 1.8A output.
